DOA Board? "UNSUPPORTED VIDEO"
(06-19-2016, 03:07 PM)phloog Wrote:
(06-19-2016, 02:17 PM)xalius Wrote: Can you post some more specifics of your setup? Link the image you wrote to the card and with what tool you did. What power supply are you using, is your HDMI display HDCP capable and can do 1080P?
Sure - and thanks, Xalius
I will state right off the bat that I can't help you much with the question "the image you wrote to the card" because I have used MULTIPLE tools to try MULTIPLE images.
The power supply that I am using was ordered with the unit from Pine64...let me just say right now that if using the Pine64-supplied power supply is causing a problem with the Pine64 board here I'm probably done here Smile ... <snip>
EDIT:  And yes, I have tried multiple displays including my Sharp Aquos that handles HDMI@1080....Not sure if this helps, but when the Pine is connected to one of the HDMI ports, the television seems to indicate that there IS something there, and it displays HDMI: 1080p ...but nothing ever shows
Please forgive me, but I don't believe you... I'm not calling you a liar, I just don't believe your story (I'm not that gullible).
If you can't answer xalius' question with specifics then you are not credible. To state you you used multiple tools and multiple images is bogus. Which specific tool did you use, with what command did you try to write the image file to the SD card, (on what OS machine) and so on... your story is not credible, and your attitude is suspect.
I am dissappointed with the Pine64 bashing going on here on this forum; its innappropriate and its not helpful.
We are not talking about a finished product here... we are talking about a super computer on an index card !  ... a computer board minus OS, display, I|O, and power... you YOU (yourself) have to be willing to work with it, and be willing to work with the community. I am noticing a lot of bashing going on, but not a whole lot of 'can do' attitude and willingness to work with the community.
Unless you ESD shocked your board (ripping it out of its static package) its fine.  I don't believe its DOA, and from what I can tell its probably more an issue of knowing what you're doing (and it doesn't seem like you do).
1) what image did you use?
2) what OS did you use to burn the image to SD?
3) what command (specifically) did you use to create the SD?
4) What SD card did you select?
5) what is the output from your diagnostic header?
6) Specifically what brand and model of hdmi display did you plug into?
7) what is the specific rating of your PSU?
marcus
DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 01:26 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 02:17 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 03:07 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by Ghost - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 04:39 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by MarkHaysHarris777 - 06-19-2016, 08:22 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-20-2016, 08:29 AM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 01:21 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-24-2016, 02:09 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ssvb - 06-24-2016, 02:38 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 02:39 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,572 10-06-2022, 08:46 PM
Last Post: ihab
  Video conferencing aproject oxoocoffee 1 3,047 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,482 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 6,783 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,405 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,524 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,287 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,853 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,245 01-15-2018, 11:21 AM
Last Post: Luke
  red led + cat5 lights but noshow on DHCP list, no video mckenna.tim 1 3,816 01-24-2017, 12:03 PM
Last Post: Luke
