slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64)
#40
(01-28-2022, 06:04 PM)dieselnutjob Wrote:
(01-28-2022, 05:27 PM)mara Wrote:
(01-28-2022, 05:21 PM)dieselnutjob Wrote: Hi Mara
If I compile and boot a kernel that I compiled myself, how do I populate /lib/modules/{version}?
currently I only have /lib/modules/{oldversion}
I can see all of the .ko files listed when the modules were compiled, but then there are all the other files like aliases
I am assuming that there is some normal way to do it that I don't know.
Until I have a /lib/modules I can't run rebuild-initrd.sh
after compiling you did:
make O=$(pwd) ARCH=arm64 INSTALL_MOD_PATH=/lib/modules modules_install
I am cross compiling on a normal PC.  Does that make a difference?
no, specify where to install the modules and then transfer to the sdcard
donation   irradium
RE: slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) - by mara - 01-28-2022, 06:09 PM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,182 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,510 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 142,033 03-23-2025, 01:10 AM
Last Post: balbes150
  USB on Quartz64 Zero litbulb 0 1,086 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,302 08-08-2024, 07:42 AM
Last Post: ifreislich
  quartz64-a - on-board SATA port problems manning 2 3,656 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,113 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,257 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,514 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 44,443 03-17-2022, 06:29 AM
