PinePhone quickly crashes unless plugged to power
I have recently changed the motherboard of my Pinephone Braveheart to switch to the 3GB version.
Since the change I have a problem: the phone crashes (instantly goes from running to powered-off) after a few minutes (between 10s. & 10 min).
If I leave the phone plugged to power (for example to a USB battery) it will not crash (not even if I use it to browse the web for 1 hour, or if I let it run idling during the night).
All other functions work fine.
The phone runs hot, but that was already the case with the original motherboard.
I am running up-to-date Mobian.
I am running from SD card, I will flash to the eMMC asap to see if it helps.
I had not this problem before changing the motherboard (crashes were rare, maybe once a month), but I was running from eMMC.
I tried logging dmesg -w to a file but this does not show anything conclusive.
Any idea for how to debug this ?
Should I try other distros ? How likely is it to be due to running from SD card ?
Thanks in advance
PinePhone quickly crashes unless plugged to power - by gab - 07-07-2021, 01:29 PM
  PinePhone - boot from microSD laserpyramid 5 307 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 105,169 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,525 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 464 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 1,941 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 384 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,480 12-22-2023, 03:44 PM
  control power management aular 0 401 12-16-2023, 12:16 PM
Last Post: aular
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,609 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Pinephone not booting, always vibrating alexander12 7 4,671 11-22-2023, 06:46 PM
Last Post: Scary Guy
