[solved] Openhab not starting
@Luke: Yes, you were right! The 8Gb version works out-of-the-box
@kai: Are you also involved in preparing these images? Maybe you can check the 16Gb version. Although, are these images fundamentally different? According to the wiki page, you execute resize_rootfs.sh anyway after the first startup so what's the difference between using the 8Gb image with the resize command and using the 16Gb image?
Anyway, thanks a lot, problem solved
[solved] Openhab not starting - by socken23 - 06-18-2016, 02:57 PM
RE: Openhab not starting - by kai - 06-20-2016, 01:47 AM
RE: Openhab not starting - by socken23 - 06-20-2016, 02:03 AM
RE: Openhab not starting - by Luke - 06-20-2016, 04:53 AM
RE: Openhab not starting - by socken23 - 06-20-2016, 11:40 AM
RE: Openhab not starting - by Luke - 06-20-2016, 12:12 PM
RE: Openhab not starting - by socken23 - 06-20-2016, 12:27 PM
RE: Openhab not starting - by socken23 - 06-20-2016, 01:37 PM
RE: [solved] Openhab not starting - by Luke - 06-20-2016, 03:24 PM
RE: [solved] Openhab not starting - by socken23 - 06-21-2016, 12:39 PM
RE: [solved] Openhab not starting - by Luke - 06-21-2016, 12:50 PM
  Pine A64 + OpenHAB + Sonoff-pow: Would it Work? Bob123456789 6 14,505 05-31-2017, 02:54 PM
Last Post: Bob123456789
Tongue Pine64 with Openhab2 - Starting guide/accessories g_t_j 4 12,689 03-12-2017, 05:13 PM
Last Post: BatoXan
  openHAB Packaging for the Pine64 kai 19 43,404 02-21-2017, 07:19 AM
Last Post: BatoXan
  Keeping Openhab current socken23 4 10,597 01-13-2017, 12:51 AM
Last Post: swinging
  OpenHAB And Zwave FrenchFrog 12 29,766 09-13-2016, 11:17 PM
Last Post: bonterra
  OpenHAB Up - Getting My Bearings - Questions doundounba 4 9,375 07-08-2016, 12:38 AM
Last Post: av1024
  openHAB just up on Pine64 :-) tllim 2 9,822 05-04-2016, 05:27 AM
Last Post: Luke
