Wipe function on mobian?
There is none builtin, however, it should be possible to add it to the screen lock. If you are using LUKs drive encryption, there are two main things that have to be wiped:
1. LUKS header - contains the encrypted key for the storage in encrypted form (the key you use is used to decrypt it)
2. the decryption key in RAM
The second is easy to make happen - have it power off the phone.
The first is hard on any storage that has built in wear leveling as flash storage often does. If it doesn't, just wiping the first few sectors of the partition is enough. Otherwise, one has to overwrite the whole storage or hope there is a feature in the storage to do a fast wipe. I am not sure whether the EMMC storage of the pine phone has built in wear leveling or not. Some microSD cards do and some don't. For those without, just writing a good MB or so of random data several times to the beginning of the encrypted partition should destroy the keys sufficiently.
Wipe function on mobian? - by Wahtone - 07-07-2021, 12:41 PM
RE: Wipe function on mobian? - by TRS-80 - 07-09-2021, 08:35 PM
RE: Wipe function on mobian? - by vortex - 07-18-2021, 06:40 AM
RE: Wipe function on mobian? - by biketool - 07-21-2021, 06:05 AM
Wipe function on mobian? - by e-minguez - 07-21-2021, 09:55 AM
RE: Wipe function on mobian? - by biketool - 07-28-2021, 06:18 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,514 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,714 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,688 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 581 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,540 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,798 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,863 06-19-2023, 03:02 PM
Last Post: vusra
  Axolotl on PinePhone / Mobian arno_nuehm 219 160,365 03-26-2023, 01:49 AM
Last Post: shulamy
