A real ATX-ish ARM64 workstation
To date, there are only 3 meaningful types of performant and readily available ARM64 desktop workstations:
- M1 Mac Mini / iMac
- Nvidia Xavier NX/AGX
- Honeycomb LX2
All other "look at me, I haz arm" devices are either laptops, puny tablets trying to imitate laptops or plain devboards with an Android image or a quarter-functional, outdated Debian..
They mostly use smartphone chips, sometimes higher frequency-binned and with a more liberal power limit. And they lack HW documentation. Or they are discontinued.
What is truly needed to kickstart the ARM64 ecosystem further is a good desktop workstation.
In such a board, I reckon there should be:
  • some kind of ATX standard form factor to mount it in a regular PC case with a regular PC power supply
  • socketed RAM
  • PCIe, USB, SATA, 3.5mm jack, RJ45..
  • a power and a force reset button
  • a chip to keep the bootloader on, so as to make the OS installation simpler
  • targetting Arm SystemReady certification, which given enough work on proper UEFI, would allow for installing OSes like on a normal PC, from a livecd etc..
  • an OSS-friendly SoC that can heat up as much as it wants - performance is key in this form factor! (without a broken PCIe implementation, I'm looking at you, Raspberry Pi...)
  • Intel-/AMD-compatible mounting holes for a cooler
  • DC/PWM fan headers (may be on a separate controller)
I was thinking, perhaps Pine could be a good vendor to tackle this? Of course, this is a complicated problem to solve, but discussion is a good thing.
A real ATX-ish ARM64 workstation - by konradybcio - 07-06-2021, 02:49 PM
  [Article] Test Bot for NuttX Pull Requests ... Tested on Real Hardware (Oz64 SG2000) lupyuen 0 2,408 02-15-2025, 11:26 AM
Last Post: lupyuen
  [Article] QuickJS JavaScript Engine on a Real-Time Operating System (Ox64 + NuttX) lupyuen 0 1,768 02-17-2024, 07:24 PM
Last Post: lupyuen
  [Article] Nim on a Real-Time Operating System: Apache NuttX RTOS + Ox64 BL808 SBC lupyuen 2 2,472 01-05-2024, 12:27 AM
Last Post: lupyuen
  [Article] $8 RISC-V SBC on a Real-Time Operating System: Ox64 + NuttX lupyuen 0 1,550 12-17-2023, 02:27 AM
Last Post: lupyuen
  [Article] RISC-V Ox64 BL808 SBC: Starting Apache NuttX Real-Time Operating System lupyuen 2 2,646 11-11-2023, 10:09 PM
Last Post: lupyuen
  power/battery usage on risc-v vs arm64? zetabeta 1 2,310 08-28-2023, 01:23 AM
Last Post: alphonso
  FreeBSD/arm64 becoming Tier 1 in FreeBSD 13 as365n4 1 3,642 04-10-2021, 09:51 AM
Last Post: dsimic
  Notebook-workstation for power users? Konstantinos 11 20,579 07-31-2019, 02:09 AM
Last Post: Konstantinos
