Getting started with an Old PineTime dev kit (flash procedure?)
(07-01-2021, 06:55 AM)danielt Wrote: Follow the wasp-os instructions to completion with one exception. Instead of installing micropython.zip install reloader-factory.zip instead. That will leave you running Infinitime Light. From there you can following the Infinitime OTA upgrade docs to get the latest Infinitime running.
I would suggest using the latest CI binaries for the wasp-os parts of the process. If you use the wasp-os v0.4 binaries you will end up with much older version of mcuboot.
For the specific instructions you want from the wasp-os documentation see:
* Install the wasp-bootloader: https://wasp-os.readthedocs.io/en/latest...or-android
* Install reloader-factory.zip: https://wasp-os.readthedocs.io/en/latest...-daflasher
Thanks for the reaction and suggestion!
In the instructions there's the part of
'Click Select DFU file again and select bootloader-daflasher.zip. Once the update is complete the watch will show the wasp-os logo and some additional on-screen prompt.'
But i'm lost at the 'bootloader-daflasher.zip'. Where can i find this file/bootloader?
It is off course in the binary zip / zip you create when compiling.
Thanks for the help Daniel
RE: Getting started with an Old PineTime dev kit (flash procedure?) - by Meurton - 07-01-2021, 12:30 PM
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,231 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,737 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,738 01-31-2024, 11:57 AM
Last Post: tynstar
