Getting started with an Old PineTime dev kit (flash procedure?)
(07-01-2021, 04:13 AM)Avamander Wrote: I can't recall anyone going through that process. Might be doable but you're on your own mostly.
It's significantly easier to simply use a hardware programmer (not a ST-Link v2) and flash it that way, it is a devkit after all.
Stlink won't work right away, as the bootloader on the initial kit is locked. I'll need a rasp pi. However, daflasher and the man bevind daflasher found the way to fix that (in a ota blue way, nice!)
https://wiki.pine64.org/wiki/PineTime_FA...tection.3F
RE: Getting started with an Old PineTime dev kit (flash procedure?) - by Meurton - 07-01-2021, 04:32 AM
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,231 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,737 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,738 01-31-2024, 11:57 AM
Last Post: tynstar
