My pbp is a sleek, black, flat brick, and won't boot from any kind of media
No boot SOLVED
My experience for what it's worth:
I went through all the suggested fixes (described in a previous post: flashing zeros to SPI, checking daughterboard cable, etc) and finally started over. I had tried so many approaches, that I was losing track. I used a second computer, a 2gb HP celeron laptop running puppy Easy OS on a usb stick.
I disabled the 64gb emmc and removed it. I had already flashed the SPI with zeros. That left only the sd slot for booting.
I downloaded balena-Etcher on the HP, unzipped it, and changed permissions to allow execution. I downloaded the Manjaro ARM KDE plasma... 21.06 . I put a 32gb Kingston HC1 "Canvas" sd into a usb multipurpose reader from IOGear Model GRR304SD and put reader into a USB 2.0 port. I used Etcher to flash the 21.06 file onto the sd card. After the file was flashed (5 min), Etcher ran a validation check which failed. I redid the flashing, and the validation check said the flashed image was fine.
So, I loaded the Kingston sd card into the bare bones PBP, held the power switch down for a minute, clicked the tiny reset button on the motherboard, pushed the power switch for a few seconds, AND, for the first time in two weeks, the PBP lit up and went into action.
One down, one to go.
I removed the sd card, enabled the emmc , pushed the power switch and got nothing. So:
I loaded the emmc card on to an Ordroid USBEEMMC (Olympian LED) reader that I bought for the purpose, and put it into the 3.0 USB port on the HP. When mounted, I looked at some of the files and found that I had previously flashed the Manjaro KDE plasma...21.07 file, the one meant for intel machines. Using Etcher again, I flashed the ARM 21.06 file that worked on the sd card.
I reinserted the emmc card in the PBP, and it worked fine. Put the sd card in as well; and that worked.
So, it was all my stupidity. I highly recommend Etcher, the Ordroid USB-Emmc reader, and the IOgear USB reader. I used the pricier sd cards to be safe. If I have trouble in the future, I would not flash zeros to the SPI until every other option failed. It took me days to do and I'm not sure that it was needed.
Loving my PBP.
RE: My pbp is a sleek, black, flat brick, and won't boot from any kind of media - by straightwalker - 06-21-2021, 09:08 PM
  3 days in, slow/stuck or no boot. lgmpbp2 34 10,228 Yesterday, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 6,222 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 4,653 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 682 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Another one boots to black screen Sb2024 7 2,146 11-06-2024, 11:27 PM
Last Post: Sb2024
  Cant boot into an OS trashtendenz 3 1,424 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 1,250 09-04-2024, 10:35 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 1,058 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 3,822 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 974 01-16-2024, 09:17 AM
Last Post: jbradley419
