My pbp is a sleek, black, flat brick, and won't boot from any kind of media
Thanks for the specifics on the how long to hold the power button. I was doing "long holds" but not with any kind of specific timing.
I'll try that first.
But if the SD card wouldn't boot _before_ I flashed the uboot, when Manjaro was working fine, it seems unlikely to boot now.
It sounds like my only options are to get the serial console on the UART going (I don't have that hardware, and I'm lousy with a soldering iron even if I had one) or get the eMMC adapter and try flashing the eMMC on my other machine. Right?
I only use dd on linux for doing image flashing, for precisely that reason that I've had bad luck with Mac disk creation in the past.
Thanks yos!
(06-19-2021, 08:18 PM)KC9UDX Wrote: What do I do? I use the serial console to see what U-Boot is doing.  If nothing, then I know I don't have a valid U-Boot.
Make sure the power is off: hold the power button for twenty seconds.  Then charge overnight with a USB-C charger.  This is important.
Don't try to boot from USB.  Disable your eMMC.  Try multiple SD-cards.  Do use only micro-sd cards in the PBPs slot, don't use any kind of adaptor.
Oh thanks. I'll run through this diligent process and see if I can get 'er to move at all.
RE: My pbp is a sleek, black, flat brick, and won't boot from any kind of media - by rotwang - 06-20-2021, 10:21 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 240 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 631 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 234 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 563 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 514 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,070 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,669 08-03-2023, 03:30 PM
  Black screen by start up bluedemon382 10 2,795 07-27-2023, 07:49 AM
Last Post: dstallmo
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 751 07-13-2023, 01:50 PM
Last Post: PaulQ
