Device unable to boot
Hi Lunix33 and welcome,
  (with this login I was not expected to see see a windows user Tongue )
If you did not solve yet your problen, you could eventually check :
- for the boot :
     - the sd is properly inserted
     - the power supply is sufficient
- for the UART (but I suppose you are aware of these points and the tuto : https://forum.pine64.org/showthread.php?tid=6387)
     - 150000 is indeed the appropriate frequency
     - the rx of the uart is linked to the tx and the ground are wired
     - the voltage is 3.3V
- flash the u-boot image in the spi and see if there are some messages sent by UART at power on even without any sd inserted
- if you have the opportunity, try with an emmc (boot method enabled in default) or usb boot (thanks to the u-boot)
good luck !
Device unable to boot - by Lunix33 - 06-15-2021, 09:51 PM
RE: Device unable to boot - by LMM - 06-20-2021, 03:18 AM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 07:51 AM
RE: Device unable to boot - by LMM - 06-22-2021, 11:58 AM
RE: Device unable to boot - by LMM - 06-22-2021, 01:09 PM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 08:17 PM
RE: Device unable to boot - by Lunix33 - 07-04-2021, 06:00 PM
RE: Device unable to boot - by t4_4t - 07-05-2021, 08:25 PM
RE: Device unable to boot - by Lunix33 - 09-22-2021, 10:31 AM
RE: Device unable to boot - by LMM - 09-23-2021, 01:38 AM
  enble boot after power loss/restore dkebler 18 9,401 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,262 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 661 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,240 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,314 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,546 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,173 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,149 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,788 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,159 06-09-2022, 10:56 AM
Last Post: pspgarret
