Pinecil died after first use, housing gets very warm plugged into USB
(06-06-2021, 03:30 AM)barray Wrote: If you think it's faulty, please don't plug it into your computer Smile Although computers tend to have short-circuit protection, it's not perfect.
Alas, pine's email support said if the device DFUs it's "working", so my only course of action was to attempt to DFU firmware on and hope that somehow fixed it...
(06-06-2021, 03:30 AM)barray Wrote: I would really not expect it to get so hot in just 5 minutes in update mode. The controller and screen should not be drawing enough current to do that.
When powering you should leave the tip connected I believe - otherwise if it is trying to heat the tip it's got nowhere but the handle to dissipate it.
Until you get to the bottom of what is going on, it's a smart idea not to leave it alone!
You should take it out of the housing and figure out where the heat is coming from - I would expect to see a chip getting pretty hot under that plastic cover - should be obvious with your thermal camera.
Prior to it dying, I tried to turn it on without a tip and the screen just shows a "no tip" inserted icon and won't heat.   No that it's dead with the tip inserted the tip still won't heat up; so that's good I think (fail safe).
I agree, I'm going to have a go at disassembling it...  Maybe the folks at Pine can see something that could be fixed for future batches.
RE: Pinecil died after first use, housing gets very warm plugged into USB - by deftdawg - 06-06-2021, 10:15 AM
  Connecting a power supply to the Pinecil jon_bondy 1 229 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 673 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 310 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 7,968 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 582 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,197 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,462 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,362 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,147 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,209 11-06-2022, 02:43 AM
Last Post: River
