Talos on ROCK64
Have you double checked your OS media and power?  These should be the first 2 things you look at when troubleshooting pretty much any issue, before even going further into some other things you speculate here.  If nothing else than to eliminate them as possibilities.
Following link is for Armbian, but most of it is generally applicable to any SBC.
https://docs.armbian.com/User-Guide_Basi...eshooting/
Don't believe me?  These are so common that we have an entire sub-forum dedicated to them:  https://forum.armbian.com/forum/31-sd-ca...su-issues/  And also why this info is mentioned first, right at the top of troubleshooting section (linked above).
Cheers,
TRS-80
Protocols, not Platforms
Talos on ROCK64 - by cjyar - 06-03-2021, 04:43 PM
RE: Talos on ROCK64 - by TRS-80 - 06-03-2021, 08:58 PM
RE: Talos on ROCK64 - by cjyar - 06-04-2021, 11:50 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 148 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,352 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 333 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 609 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 606 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,350 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,285 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 590 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 649 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,288 12-07-2022, 08:22 PM
Last Post: luminosity7
