what if problem cant be solved
(06-07-2021, 11:09 AM)rvh Wrote:
(06-05-2021, 04:01 PM)dsimic Wrote: There's no "hidden" firmware in the PinePhone, so you shouldn't be worried about some firmware "viruses" and such stuff.  Could the touchscreen digitizer on your PinePhone be defective?  I'd suggest that you boot the factory test image and use it to test out the digitizer on your PinePhone.
I tried the factory test. the whole left side was unresponsive. I there a fix for this or is the phone toast?
Based on that, it's safe to conclude that the touchscreen digitizer is defective.  I'd suggest that you open a ticket with the Pine64 support, and ask them for an advice; they might offer to send you a replacement screen.
what if problem cant be solved - by rvh - 06-03-2021, 03:49 PM
RE: what if problem cant be solved - by dsimic - 06-04-2021, 03:42 PM
RE: what if problem cant be solved - by ryo - 06-05-2021, 06:12 AM
RE: what if problem cant be solved - by rvh - 06-05-2021, 03:18 PM
RE: what if problem cant be solved - by dsimic - 06-05-2021, 04:01 PM
RE: what if problem cant be solved - by rvh - 06-07-2021, 11:09 AM
RE: what if problem cant be solved - by dsimic - 06-11-2021, 01:06 AM
RE: what if problem cant be solved - by bosi564 - 06-06-2021, 02:32 AM
  Problem with incoming calls (w/o ModemManager/Ofono) jlucas 10 679 08-09-2021, 05:38 PM
Last Post: mouffa
  Importing vcf, country prefix problem workaround p1trson 3 1,406 12-02-2020, 09:29 AM
Last Post: cybercow
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 727 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  Problem With Headphones Joelandsonja 0 673 07-22-2020, 01:49 PM
Last Post: Joelandsonja
  PinePhone RTL8723CS automatic test fail and WiFi problem surfingtux 4 2,317 02-19-2020, 12:24 PM
Last Post: surfingtux
