what if problem cant be solved
(06-05-2021, 04:01 PM)dsimic Wrote: There's no "hidden" firmware in the PinePhone, so you shouldn't be worried about some firmware "viruses" and such stuff.  Could the touchscreen digitizer on your PinePhone be defective?  I'd suggest that you boot the factory test image and use it to test out the digitizer on your PinePhone.
I tried the factory test. the whole left side was unresponsive. I there a fix for this or is the phone toast?
what if problem cant be solved - by rvh - 06-03-2021, 03:49 PM
RE: what if problem cant be solved - by dsimic - 06-04-2021, 03:42 PM
RE: what if problem cant be solved - by ryo - 06-05-2021, 06:12 AM
RE: what if problem cant be solved - by rvh - 06-05-2021, 03:18 PM
RE: what if problem cant be solved - by dsimic - 06-05-2021, 04:01 PM
RE: what if problem cant be solved - by rvh - 06-07-2021, 11:09 AM
RE: what if problem cant be solved - by dsimic - 06-11-2021, 01:06 AM
RE: what if problem cant be solved - by bosi564 - 06-06-2021, 02:32 AM
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,240 07-07-2023, 12:06 PM
Last Post: jovval
  Boot problem: wrong screen orientation Jetpac 6 3,783 07-18-2022, 12:47 PM
Last Post: fravoi
  gnome-online-accounts won't sign in to google account [SOLVED] pjsf 0 1,153 04-27-2022, 07:32 PM
Last Post: pjsf
Sad [Solved] My phone won't boot with SD card inserted AKD251 4 3,503 11-08-2021, 02:05 PM
Last Post: AKD251
  Problem with incoming calls (w/o ModemManager/Ofono) jlucas 10 7,604 08-09-2021, 05:38 PM
Last Post: mouffa
  Importing vcf, country prefix problem workaround p1trson 3 4,401 12-02-2020, 09:29 AM
Last Post: cybercow
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 1,723 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  Problem With Headphones Joelandsonja 0 1,506 07-22-2020, 01:49 PM
Last Post: Joelandsonja
  PinePhone RTL8723CS automatic test fail and WiFi problem surfingtux 4 5,691 02-19-2020, 12:24 PM
Last Post: surfingtux
