Advice on building a simple computer…
(05-24-2021, 05:07 PM)SeeMossRun Wrote:
(05-24-2021, 12:09 AM)barray Wrote: @SeeMossRun This is a very open-ended question. Please be more specific.
Perhaps this community is too advanced.  The question is straight-forward.  The OP seeks resources and instructions for assembling a computer from component parts.  The poster has no such experience . . .
The question is not simple, depending on what you are asking. For example:
* If you're looking to build a normal PC, LinuxTechTips could be a good starting point: https://www.youtube.com/playlist?list=PL...4578XfgJm_
* If you're looking for some 'DIY' laptop but don't want to build your own hardware, checkout something like a Pi-Top: https://www.pi-top.com/products/pi-top-3
* If you're looking for an open source laptop that you can do your own hacking to, checkout the Pinebook Pro: https://www.pine64.org/pinebook-pro/
* If you're looking to build a laptop from scratch, you're limited to whatever guides you can find online and you will definitely need to do some hardware yourself.
It's not clear what your goal is, so it's not obvious whether you are asking your question in the right place.
RE: Advice on building a simple computer… - by barray - 05-24-2021, 05:25 PM
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 3,787 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  Star64/Starpro64 kernel building global 0 1,585 10-04-2024, 08:36 PM
Last Post: global
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 1,685 08-23-2024, 12:45 PM
Last Post: Octaviah
  LD error building uboot lash 2 2,136 06-09-2024, 03:05 PM
Last Post: lash
  Im thinking of building a Pine64 cluster Theirat1991 1 2,602 01-12-2024, 03:31 AM
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 3,005 03-10-2023, 03:35 PM
Last Post: peteressive
  Building Kernel App for fast GPIO nimblemotors 0 2,109 05-21-2021, 11:56 PM
Last Post: nimblemotors
  Simple Unixy mistakes that will ruin your day KC9UDX 7 9,840 02-01-2021, 10:47 PM
Question Micro computer module Computer semi-expert 7 11,870 09-29-2020, 04:52 PM
  What are the chances of getting a pine64 mini computer Omnios 4 8,036 09-06-2020, 04:04 AM
Last Post: SpoofyKid
