can't get file transfer working. Help, please!
#19
My next choice if sshfs won't work would be probably be to set up ftp. Other options would include installing Samba for Windows networking, or if you're connecting from a Unix/Linux system you could use NFS. With anything that exposes your files to the network you would want to protect it with a firewall or run it only when needed.
I actually consider sshfs to be the simplest because if you have ssh working sshfs will work as well, nothing more to set up, and I always have ssh going on the Linux systems I work with. (The numerical password works fine with ssh by the way, used it that way on the Pinephone before setting up key-based login.)
Actually if I want to transfer a lot of files or very large files I'll sometimes take the SD card out and plug it into my desktop computer. It's a lot faster than copying them over the network.
RE: can't get file transfer working. Help, please! - by Zebulon Walton - 05-18-2021, 11:14 PM
  New camera app gnome-snapshot working on trixie? vusra 4 2,770 04-11-2025, 02:53 AM
Last Post: vusra
  Short Guide to Using OpenVPN client GUI and .ovpn config file on PP biketool 0 2,473 12-16-2024, 02:07 PM
  Calls 4G not working oliwierzgorniak 2 3,848 08-06-2024, 02:20 PM
Last Post: baptx
  Mobile internet via cellular network mostly not working Anna 18 20,301 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 5,411 01-17-2024, 05:53 PM
  APN settings not working with new operator SIM card user641 1 2,525 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 2,029 02-13-2023, 01:09 PM
Last Post: Ferriah
  Squeekboard stopped working Zebulon Walton 2 3,261 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 4,149 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  low disk space on file system root revisited benedikt55 2 3,325 09-24-2022, 10:16 AM
Last Post: benedikt55
