Boot problems
Some of manjaro's uboots are not so good
On a SD, where it is easy, backup good uboots before changing
bs=1M count=16 of=suitable_name,,, since it is same device, no need to mess with mbr
It is not sure if or maybe not some uboot remnant on emmc, this may or may not interfere
(from failed installs)
Because there is a battery, it can remember a "bad state", you may have to do "long presses"
Easiest to reburn image on SD, as your dd command line
If it then boots, then try to install
The long press dance........
If not, hard pwr-off(8s), try start (don't just tap, hold 1-2s, try twice (or 3) times)
If not, hard reset (20+s), try start
if not, try hard pwr-off again
I actually have had to this above dance, somewhat annoying
Boot problems - by jessef - 05-10-2021, 06:36 AM
RE: Boot problems - by wdt - 05-10-2021, 12:17 PM
RE: Boot problems - by djhnsn - 05-11-2021, 01:47 AM
RE: Boot problems - by jessef - 05-11-2021, 04:18 PM
RE: Boot problems - by wdt - 05-11-2021, 02:06 PM
RE: Boot problems - by djhnsn - 05-14-2021, 01:17 PM
RE: Boot problems - by jessef - 05-12-2021, 05:24 PM
RE: Boot problems - by wdt - 05-12-2021, 11:33 PM
RE: Boot problems - by jessef - 05-14-2021, 04:47 PM
RE: Boot problems - by wdt - 05-14-2021, 02:50 PM
RE: Boot problems - by djhnsn - 05-15-2021, 08:11 PM
RE: Boot problems - by djhnsn - 05-16-2021, 11:13 AM
  Boot Order in Pinebook Pro food 11 12,222 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,305 08-21-2024, 04:17 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,642 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 5,466 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 16,470 06-02-2023, 01:32 PM
  Big bluetooth problems ColoBill 2 3,376 12-15-2022, 01:38 PM
Last Post: ColoBill
  Tow Boot install help Paulie420 7 9,416 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 4,833 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 2,684 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 9,987 08-18-2022, 11:47 AM
Last Post: Bemo
