Touchpad notchy on new 2021 pinebook pro
I thought the Numlock behaviour that you describe was an intentional feature. I seem to recall reading that you have to hold Fn to get numbers all the time because the author of the new firmware didn't like the standard Numlock functionality. This was the sole reason I never used that firmware.
I'm not using the Synaptics driver (it's not available for NetBSD currently). I did finally get round to documenting the settings I use in KDE (v4) to make the touchpad most usable:
Pointer acceleration: 10.0x
Pointer threshold: 6 pixels
Double click interval: 400 msec
Drag start time: 500 msec
Drag start distance: 1pixel
Mouse wheel scrolls by: 3 lines
Mouse wheel emulation does not currently work, so that setting isn't relevant for me.
My touchpad recently has devolped a new problem making it all but unusable. I may have to tweak the settings again but I'm not sure that will help. What it does now is detect every touch as a double-tap. So every movement is drag or select.
RE: Touchpad notchy on new 2021 pinebook pro - by KC9UDX - 06-05-2021, 12:13 AM
  Replacement battery for PineBook Pro DrYak 5 6,131 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,656 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,406 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 3,971 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,553 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,505 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,059 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 207,536 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 13,248 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 11,640 12-27-2022, 03:31 PM
Last Post: samtux
