Cant update and upgrade mobian.
(05-04-2021, 09:16 PM)MtnSk8 Wrote: You should be able to refresh the apt lists by:
1 Make a backup of your apt lists
sudo cp -R /var/lib/apt/lists/* ~/lists/
2 Remove apt lists
sudo rm -R /var/lib/apt/lists/*
3 Repopulate
sudo apt-get update
Cheers!
Thanks.
Cant update and upgrade mobian. - by mode80 - 05-04-2021, 02:13 PM
Cant update and upgrade mobian. - by vongillus - 05-04-2021, 02:21 PM
RE: Cant update and upgrade mobian. - by mode80 - 05-04-2021, 03:10 PM
RE: Cant update and upgrade mobian. - by MtnSk8 - 05-04-2021, 09:16 PM
RE: Cant update and upgrade mobian. - by mode80 - 05-05-2021, 10:46 PM
RE: Cant update and upgrade mobian. - by bcnaz - 01-06-2022, 04:19 PM
RE: Cant update and upgrade mobian. - by susy1075 - 01-06-2022, 04:08 AM
  Mobian repository status henrythemouse 16 8,720 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,966 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 127 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,975 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,802 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 629 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,872 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,890 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 626 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,004 06-19-2023, 03:02 PM
Last Post: vusra
