Good i3 Config file to use?
since you got ahold of me i might aswell tell you all my pmos sway secrets
i try to to put all my edits into /etc/sway/confing.d/ short and sweet per objective
cat /etc/sway/config.d/pbp.pipewire   (audio server)
exec pipewire
exec pipewire-pulse
exec pipewire-media-session
locker/blanker
cat /etc/sway/config.d/pbp.idlelock
# locker
exec swayidle -w timeout 360 '/usr/local/bin/swaylock --clock --effect-pixelate 4 --screenshots --grace 30 '
# blanker
exec swayidle -w timeout 390 'swaymsg "output * dpms off"' resume 'swaymsg "output * dpms on" '
(the default config directive wasnt working for me with multiple lines so i broke it into two and now it works for me also using a self compiled swaylock-effects since its not yet in the pmos packages should really push an abuild for it)
misc stuff
exec foot -s    (and change $term to footclient)
bindsym print exec cd ~Pictures/Screenshots && grim -g "$slurp"  #printscreen screenshotter with grim/slurp
i really like pmos its so fast and small everything else is bloated and slow in comparison haha problem is theres no stable build and if you update daily or at the wrong time and reboot... could be devastating like right now im looking at self compiling a kernel cause its missing a bunch of modules i wanna use namely usb-storage for when something inevitably breaks from running edge-ware
Good i3 Config file to use? - by User 22018 - 05-04-2021, 07:49 AM
RE: Good i3 Config file to use? - by shjim - 05-04-2021, 09:07 AM
RE: Good i3 Config file to use? - by User 22018 - 05-04-2021, 12:53 PM
RE: Good i3 Config file to use? - by shjim - 05-05-2021, 03:04 AM
RE: Good i3 Config file to use? - by user526 - 06-16-2021, 06:09 PM
RE: Good i3 Config file to use? - by user526 - 06-16-2021, 06:11 PM
RE: Good i3 Config file to use? - by user526 - 06-17-2021, 09:38 AM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,326 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  extlinux.conf file error, can it be edited in bootloader? Abandoned Brain 2 2,486 09-26-2021, 01:28 PM
Last Post: Abandoned Brain
Brick Anyone know of a good firewall? SpaceLord 6 5,815 07-24-2021, 12:04 PM
Last Post: globaltree
  PostmarketOS - Why swap file not on at boot? stozi 3 3,845 06-24-2021, 12:27 AM
Last Post: craftyguy
  Network settings, where to find the config files? hvdkooij 1 2,788 11-20-2020, 02:47 PM
Last Post: xyzzy
  Pinebook Pro Sleep/Resume bug: The (Kinda sorta) Good, The Bad, and the (Very) Ugly. feoh 12 12,998 09-30-2020, 09:01 AM
Last Post: feoh
  Restoring img file to eMMC GloriousCoffee 5 5,631 08-08-2020, 10:49 AM
Last Post: GloriousCoffee
  Anyone planning on ZFS or BTRFS for file systems? Arwen 16 18,056 06-17-2020, 02:04 PM
Last Post: DrYak
  Manjaro Arm users - What does your trackpad/keyboard conf file look like? Eggmonkey 7 7,696 04-21-2020, 08:27 AM
Last Post: Surehand53
  Which keyboard config file with Ubuntu Mate Linux-Rob 1 2,256 11-19-2019, 01:57 PM
Last Post: agD0i7rY
