Cellular Data, Mobian - "No WWAN Adapter Found"
This command will power cycle the modem on Mobian. Commands are case-sensitive.
sudo systemctl restart eg25-manager.service
Then check the log by running:
sudo journalctl -u eg25-manager.service -n 100
If the modem is detected you will get something like this
systemd[1]: Stopped Quectel EG25 modem.
systemd[1]: Started Quectel EG25 modem.
eg25manager[5586]: Opening config file: /usr/share/eg25-manager/pine64,pinephone-1.2.toml
eg25manager[5586]: Starting modem...
eg25manager[5586]: Executed power-on/off sequence
eg25manager[5586]: taking systemd sleep inhibitor
eg25manager[5586]: ModemManager appeared on D-Bus
eg25manager[5586]: inhibitor sleep fd is 21
eg25manager[5586]: Response: [RDY]
eg25manager[5586]: taking systemd sleep inhibitor (blocking)
eg25manager[5586]: inhibitor block fd is 20
eg25manager[5586]: ModemManager object `/org/freedesktop/ModemManager1/Modem/3' added
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Simple' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Firmware' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Voice' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Time' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: ModemManager interface `org.freedesktop.ModemManager1.Modem' found on object `/org/freedesktop/ModemManager1/Modem/3'
eg25manager[5586]: Adding new modem `/org/freedesktop/ModemManager1/Modem/3'
If it did not work, posting a log might help figure out the situation.
RE: Cellular Data, Mobian - "No WWAN Adapter Found" - by awaittrot - 05-03-2021, 03:08 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,611 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 16,992 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  how to backup user data? Uturn 1 615 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,182 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US cellular service (as I understand it as of post date) freebsd 17 8,870 07-23-2023, 04:57 PM
Last Post: kb-zealot
  No sound after Mobian upgrade arbocenc 1 696 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,003 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  cell data and MMS on AT+T prepaid ossands 2 1,369 10-13-2022, 07:28 AM
Last Post: ossands
  pinephone-support package not upgradable on Mobian fhireman 4 2,210 09-24-2022, 08:01 AM
Last Post: dante404
  Cannot Remove SIM Adapter CheeseEBoi 1 1,065 07-09-2022, 04:07 PM
Last Post: mcjonmor
