Another sudden Pinecil death
I received a pinecil from the latest batch today - sadly it only worked 2 times - once plugged into 20v via DC jack. The other time in a QC3 usb-c socket with a negotiated voltage of 15v.
During heating of a D24 TS-100 tip 8.Ohm@15V via usb-c the OLED screen froze and the buttons became unresponsive. After unplugging and reconnecting the pinecil the screen stayed off. The DFU mode also does not trigger. The pinecil does not show up as a USB device.
Further investigation resulted in the following: the pinecil when supplied with power via USB-c will consume about 120mA. A visual inspection of the pinecils board does not show any obvious damage or soldering faults.  The DC-DC converter (U8) on the board gets hot. The 3v3 regulator (U5) also gets hot. The 5v rail voltage is at ~4.0v. The 3.3v rail appears to be shorted to ground.
A cracked smd cap would explain this short very handily and this matches the accounts of a couple of other posts i saw in here. I already made a ticket in the pine64 system.
Another sudden Pinecil death - by falk - 04-30-2021, 02:27 PM
RE: Another sudden Pinecil death - by deftdawg - 06-04-2021, 01:49 AM
  Connecting a power supply to the Pinecil jon_bondy 1 349 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 771 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 360 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,230 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 654 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,276 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,542 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,435 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,233 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,248 11-06-2022, 02:43 AM
Last Post: River
