PineTab Mobian Upgrade issue - Pin no longer works
I was able to update through the software app the following time after that successfully!  Maybe the issue is fixed now after you upgrade to a certain point.
Now that I have a working system, I am most impressed with the battery life at idle.  I could use it for light browsing and brief research for several days and it stayed above 90% battery.
RE: PineTab Mobian Upgrade issue - Pin no longer works - by thomzane - 04-30-2021, 06:52 AM
  PineTab 2 login screen rotation fix chzbacon 11 3,577 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 1,879 02-24-2024, 12:29 PM
Last Post: Evergreen
  Release upgrade failed! Or not? jojuma 4 461 02-23-2024, 01:52 AM
Last Post: jojuma
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 2,353 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 3,363 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 627 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 4,305 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,027 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,256 08-05-2023, 05:08 PM
Last Post: bingch
  Mobian - Phosh frtodd 1 1,173 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
