Cannot boot from SD cards any longer.
Do you have the serial cable for the device? If so can you get the console output when you try booting into Jumpdrive? I've been having a similar problem where the boot process would hang before getting to the Linux init.rd. So far the only image I have found that will boot from an SD card is the latest beta for Manjaro with Plasma Mobile. I suspect that there is some boot firmware that is not configuring the power management IC correctly (the AXP803). On occasion the image flashed to the eMMC will hang trying to probe this part.
Having the console output during the boot would be helpful in diagnosing the problem. If you are able capture it while trying to boot several different images, the outputs can be compared to try and isolate the problem.
RE: Cannot boot from SD cards any longer. - by Marcade - 04-16-2021, 02:50 PM
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 185 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 450 03-06-2024, 06:37 PM
Last Post: aular
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,158 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,685 08-20-2023, 02:44 AM
Last Post: spha
  pinephone no longer receiving calls or texts jyoung 3 1,772 07-16-2023, 10:05 PM
Last Post: jyoung
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,434 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 242,830 03-05-2023, 11:04 AM
Last Post: Eugo
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,226 02-03-2023, 01:27 AM
Last Post: dante404
  No longer waking up from sleep after recent update gamerminstrel 2 1,267 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  no sdcard boot and manjaro update failed Gwen 3 1,367 11-27-2022, 07:56 AM
Last Post: fxc
