Cannot boot from SD cards any longer.
(04-16-2021, 11:12 AM)neil_swann80 Wrote: Really odd.
Have you tried a thorough wipe of one of the MicroSDs before flashing an image?
Mounted in linux you can run:
sudo dd if=/dev/zero of=/dev/sdX
(where sdX is the device of the drive to delete)
In windows (cmd) you can run diskpart, select the drive, then "clean all".
What method/tool are you using for the flash?
Are you using your Pinephone without a sim currently?  If so, are you possibly putting the microsd in the sim slot by accident?  Easily done, it does fit a little to nicely in the sim slot and you wouldn't be the first... I'm guilty of that silly error myself!  (unlikely as you said you can see the card via lsblk... but throwing it out there)
Thanks for the suggestions.  Unfortunately they don't make a difference.  I'm positive the SD is in the correct slot .  As I mentioned above, I can see it in the terminal on the device when I run lsblk.  Regarding flashing, I normally use balenaEtcher as it's been foolproof but I've tried with dd and doing a full zeroing of the card.  All the same problem: no attempt to boot from the SD card. Sad
RE: Cannot boot from SD cards any longer. - by MadHopsMan - 04-16-2021, 01:19 PM
  PinePhone - boot from microSD laserpyramid 5 305 03-06-2024, 06:37 PM
Last Post: aular
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,007 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,465 08-20-2023, 02:44 AM
Last Post: spha
  pinephone no longer receiving calls or texts jyoung 3 1,694 07-16-2023, 10:05 PM
Last Post: jyoung
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,344 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 240,294 03-05-2023, 11:04 AM
Last Post: Eugo
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,098 02-03-2023, 01:27 AM
Last Post: dante404
  No longer waking up from sleep after recent update gamerminstrel 2 1,210 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  no sdcard boot and manjaro update failed Gwen 3 1,301 11-27-2022, 07:56 AM
Last Post: fxc
  Tow-boot on Pinephone beta edition saddamus 10 5,094 09-11-2022, 02:43 PM
Last Post: saddamus
