Some keyboard keys not working
Until recently, my PBP was working absolutely fine. However when I turned it on the day, after some confusion I realized that some of the keys simply don't work. Quite a lot in fact. I'm using an external USB keyboard at the moment which does work. So far I've has no luck in diagnosing the problem or whether it's simply a hardware failure. The last thing I did before powering off was to do a full update on Manjaro but I find that hard to believe that would cause this, who knows.
Couple of points
1. I have the ANSI keyboard
2. I've tried booting archlinux from an SD card to check that it wasn't something in Manjaro. It exhibits the same behaviour
3. Tried re-flashing the keyboard firmware (only once) to see if something had gone awry there. No change
4. Popped the bottom of visually inspect the cables. As far as I can tell, everything looks connected properly
Is there anything I can do to confirm if it's a hardware, firmware or software issue? I'm I out of luck and the keyboard is toast?
Thanls.
Some keyboard keys not working - by oddsocks - 04-11-2021, 10:00 PM
RE: Some keyboard keys not working - by dsimic - 04-12-2021, 01:22 AM
RE: Some keyboard keys not working - by oddsocks - 04-12-2021, 05:47 PM
RE: Some keyboard keys not working - by KC9UDX - 04-12-2021, 02:13 AM
RE: Some keyboard keys not working - by oddsocks - 04-12-2021, 05:45 PM
RE: Some keyboard keys not working - by dsimic - 04-12-2021, 02:19 AM
RE: Some keyboard keys not working - by oddsocks - 04-14-2021, 02:45 AM
RE: Some keyboard keys not working - by dsimic - 04-14-2021, 11:01 AM
RE: Some keyboard keys not working - by KC9UDX - 04-14-2021, 04:16 PM
RE: Some keyboard keys not working - by ab1jx - 04-14-2021, 08:44 PM
RE: Some keyboard keys not working - by dsimic - 04-20-2021, 08:33 AM
  New Working nVME gilwood 1 2,996 11-17-2024, 04:24 AM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 3,831 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 203,921 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 2,308 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 2,396 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 5,664 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 10,954 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 2,800 11-29-2021, 01:55 PM
Last Post: stozi
  UART switch not working [EDIT: I got it working] kileel 5 7,172 10-24-2021, 11:17 PM
  pinebook pro trackpad randomly stops working chewie 5 9,420 08-10-2021, 04:33 PM
Last Post: chewie
