Wifi Troubles
If you can't connect on the same band that you can connect to as "guest" then it's a operating system-or-after problem on the PBP, or bad configuration at the access point. It won't be hard to narrow down. It cannot be the hardware or firmware.
Wifi Troubles - by IDEFK - 04-11-2021, 07:40 AM
RE: Wifi Troubles - by calinb - 05-06-2021, 04:21 AM
RE: Wifi Troubles - by calinb - 05-06-2021, 07:07 PM
RE: Wifi Troubles - by KC9UDX - 05-06-2021, 08:08 PM
RE: Wifi Troubles - by calinb - 05-06-2021, 11:03 PM
RE: Wifi Troubles - by KC9UDX - 05-07-2021, 01:34 AM
RE: Wifi Troubles - by calinb - 05-07-2021, 03:40 AM
RE: Wifi Troubles - by line72 - 05-07-2021, 06:02 AM
RE: Wifi Troubles - by calinb - 05-07-2021, 12:07 PM
RE: Wifi Troubles - by calinb - 05-07-2021, 03:38 PM
RE: Wifi Troubles - by calinb - 05-07-2021, 04:39 PM
RE: Wifi Troubles - by calinb - 05-08-2021, 02:03 AM
RE: Wifi Troubles - by walterbe - 05-12-2021, 12:19 PM
RE: Wifi Troubles - by calinb - 05-12-2021, 05:26 PM
RE: Wifi Troubles - by walterbe - 05-13-2021, 01:16 AM
RE: Wifi Troubles - by walterbe - 05-23-2021, 04:02 PM
RE: Wifi Troubles - by jiyong - 05-24-2021, 04:04 AM
RE: Wifi Troubles - by walterbe - 05-24-2021, 05:03 AM
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 892 03-31-2025, 07:14 AM
Last Post: Anarethos
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 1,535 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 1,114 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 3,563 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 1,957 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 2,779 11-07-2021, 12:58 AM
Last Post: dukla2000
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 17,590 05-23-2021, 04:35 AM
Last Post: Ralim
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 4,229 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 4,001 01-21-2021, 10:21 AM
Last Post: moonwalkers
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 2,347 01-17-2021, 01:50 PM
Last Post: BananaPekan
