Unable to mount the INTERNAL SD Card
(03-29-2021, 11:50 PM)evilbunny Wrote:
(03-29-2021, 10:46 PM)dgdimick Wrote:  formatted exfat,
Linux can't handle exfat without installing the exfat library...
Thanks for the reply,
I should have been clearer, I have installed the exfat libs. I assumed by stating that I can mount the SD card using a USB adapter and a OTG cable would have been inferred this - my bad for being unclear.
I do thank you for making sure I'd installed the libs, since this could be a core issue.
Any other ideas?
(03-29-2021, 11:11 PM)RTP Wrote:
(03-29-2021, 10:46 PM)dgdimick Wrote: I've tried with a few SD Cards now, both 512 Gig formatted exfat, and tge cards are not showing up on boot, "dmesg" and "lsblk" are not showing them as well.
I'm running Phosh, is it an issue with Phosh?
I'm able to mount the SD Card via an OTG cable, as well as a Windows computer
what do you see when you run this directly after inserting card:
sudo dmesg | tail -20
Thanks for the reply.
Since the SD Card is installed in the Slot INSIDE the phone, I'm not sure what your asking. I've run dmesg a number of times trying to find any "/dev" entries.
When I use the OTG and an SD Card to USB adapter it comes up as /dev/sda1 and allows me to mount it, R/W.
RE: Unable to mount the INTERNAL SD Card - by RTP - 03-29-2021, 11:11 PM
RE: Unable to mount the INTERNAL SD Card - by dgdimick - 03-30-2021, 07:45 PM
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 1,911 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 2,876 08-22-2023, 12:22 PM
  Device memory full on multi-boot SD card Peter Gamma 4 5,158 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 5,915 08-17-2022, 03:38 AM
Last Post: shulamy
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 5,287 05-02-2022, 06:57 AM
  Writing to SD card possible with all applications? Peter Gamma 5 6,177 03-28-2022, 07:12 AM
  Linux Mint can't mount image made with dd nelstomlinson 0 1,915 11-11-2021, 10:59 AM
Last Post: nelstomlinson
  Launching OS in the SD card from p-boot in MMC chuso 0 2,042 10-01-2021, 09:02 AM
Last Post: chuso
  Silly Kali Linux script for Mobian SD card sergio.pantalone 0 4,362 03-08-2021, 10:08 PM
Last Post: sergio.pantalone
  SD card mounted to access music files unable to play dcinoz 3 5,578 02-24-2021, 11:48 PM
Last Post: dcinoz
