04-05-2021, 07:44 AM
It seems plausible, at least for apps that can use X, since forwarding over ssh via wifi works. The main sticking point is that most pinephone OS images are using Wayland, so you often have to set an environment variable to get the app to start using X instead of Wayland, and the variable to set usually depends on which toolkit the app is using.
