using sd card
(03-28-2021, 03:31 PM)rvh Wrote: Blush i would like to put some movies and pdf files on my sd card. is there a way to do that?
Not sure which scenario you have...
1. If you are running your OS from the sd card, then your files are probably already there.
2. If you are running your OS from the sd card and want to copy files from your computer to there, then shut down the pinephone, take out sd card, insert it into your computer (prefer linux computer) and copy your files to the card into /home/yourusername directory. yourusername depends what is your user name in Pinephone
3. If you are running your OS from the internal memory and you have also a data sd card inserted, then it is relatively easy for example in Manjaro&Plasma. Open the file manager (Index), swipe from the left to get root menu, touch your sd card and it gets mounted somewhere in /run/media/yourusername/... . Then just copy your files from your internal memory to sd card using the same file manager. Other OS's should behave similarily.
using sd card - by rvh - 03-28-2021, 03:31 PM
RE: using sd card - by acrux - 03-29-2021, 01:31 AM
RE: using sd card - by xalius - 03-29-2021, 02:18 AM
RE: using sd card - by rvh - 03-29-2021, 05:13 PM
RE: using sd card - by Zebulon Walton - 03-29-2021, 05:45 PM
RE: using sd card - by xalius - 03-29-2021, 05:46 PM
RE: using sd card - by rvh - 04-03-2021, 03:54 AM
RE: using sd card - by tllim - 04-07-2021, 02:49 PM
  install iso from sd card to emmc aular 2 325 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 942 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,367 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 6,141 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,473 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 2,024 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,422 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 5,131 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 2,204 02-12-2022, 11:09 AM
Last Post: dekrets
  I just got to find phone in my sd card won't read Tyro 5 5,999 11-15-2021, 01:11 AM
Last Post: alexenwaston
