USB3 SATA
You might be interested in this thread, there is a lot of good info there about using sata drives with the rock64
https://forum.armbian.com/topic/5098-min...ata-cable/
I believe the rock64 usb3 port is rated at 950ma - https://forum.pine64.org/showthread.php?...4#pid29804 - I haven't used the usb3 port to power sata drives personally though.
I have a rock64 + 4 disk usb3 icybox enclosure running (externally powered) and I haven't had any problems related to the drives.
USB3 SATA - by ReleaseTheGeese - 03-28-2021, 02:17 PM
RE: USB3 SATA - by aog - 03-29-2021, 06:45 AM
RE: USB3 SATA - by ReleaseTheGeese - 04-04-2021, 12:55 PM
  USB3 to SATA cable - Firmware Eule 0 2,189 03-03-2020, 01:31 PM
Last Post: Eule
  USB3 enough to power 2,5 external HDD? va88 11 14,181 06-06-2019, 03:40 PM
Last Post: va88
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 1,754 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  unable to switch usb3 ports on cglhu 6 7,998 05-17-2018, 08:43 AM
Last Post: cglhu
  USB 3 2.5" SATA Case thewonderer 2 3,759 12-13-2017, 06:05 PM
Last Post: thewonderer
  Best USB3.0 to SATA bridge mikedhoore 6 15,021 10-02-2017, 07:52 AM
Last Post: mikedhoore
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 3,654 09-30-2017, 06:48 AM
Last Post: dkryder
