Session start fails, need to reinstall?
I tried with bmap-tools from Trisquel repository on my desktop (amd86) , it is v3.4. I had the bmap file. The issue could be a syntax mistake, but since I wanted the result quickly and I knew that dd only takes a few minutes to flash a file that size on a microSD card, I thought it would be the case here too (and it was) so I gave up bmaptool without searching further.
I used bs=64k as in the example. In what sense is the result "better" with bs=512 as compared with bs=1M?
Besides, when it comes to writing to /dev/sdX, I have already read the advice to just use cp and indeed it worked. I always run sync after dd or cp in this case but I don't know whether it is really necessary.
RE: Session start fails, need to reinstall? - by Avron - 03-24-2021, 08:48 AM
  Errors when start the system kubussz 2 532 11-21-2023, 11:07 AM
Last Post: kubussz
  Auto start application on Phosh login Zebulon Walton 8 3,297 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Receive MMS fails after Nov 27 upgrade treebeard 17 5,852 12-12-2022, 05:09 AM
Last Post: anonymous
Sad Chatty can no longer start since the last update anonymous 10 5,305 06-08-2022, 01:03 PM
Last Post: Korac
  Backing up SMS and phonebook before wipe/reinstall biketool 2 1,427 05-09-2022, 09:20 PM
  Issues with Mobian? Start here. tophneal 0 4,905 04-21-2022, 11:27 AM
  Session app Oxen/Loki jmcsys 1 1,504 10-09-2021, 06:31 PM
Last Post: lacriz
  When to dist-upgrade vs when to reinstall? DrPlamsa 5 2,684 08-02-2021, 06:23 PM
Last Post: bcnaz
  How Do I Perform a Chatty Application Reinstall? rrholmes 2 2,372 07-13-2021, 01:11 AM
Last Post: rrholmes
  (Gnome) Maps won't start on Mobian? TRS-80 3 3,185 07-11-2021, 12:09 PM
Last Post: TRS-80
