Issues with Mobian 20210314 (data and updates)
(03-17-2021, 05:52 AM)Tharadash Wrote:
(03-16-2021, 12:26 PM)IMSAI8080 Wrote:
(03-16-2021, 10:32 AM)dukla2000 Wrote:
Hi there - I would try get the mods to move this to the PinePhone/Mobian forum!
(03-16-2021, 03:20 AM)IMSAI8080 Wrote: ..
Unfortunately, data download never started working (although, I have the 4G symbol activated and four bars). Of course, set the APN.
Under Settings, Mobile do you have Mobile Data enabled?
(03-16-2021, 03:20 AM)IMSAI8080 Wrote: ...
WI-FI works as well but, oddly, using it, my phone is unable to download updates ("The following packages have unmet dependencies").
In general I don't get that with Mobian - it means apt has got its knickers in a twist which is a generic Debian issue you can ask Prof Duckduckgo about. But on the basis it is uncommon in Mobian I would recommend doing your download/flash again in case something is corrupt there.
Ops... wrong forum, sorry for the oversight.
Anyway, thanks dukla2000 for your answer and... yes, data enabled.
Asked Prof. Duckduckgo, before posting the tread: the steps suggested to fix the problem require an OS update, after the terminal work.
That's why I wrote about the updating issue in the same thread.
Think that the easier way for me is to reflash the SD and hope for the best.
Ciao
PS: moving the chat above to the right forum: how, coping and paste?
Have you read this mobian blogpost?
https://blog.mobian-project.org/posts/20...pam_issue/
There they write:
Quote:You will get some mysterious “Cannot update due to unmet dependencies” error in the software app if you try. So for the initial update, we recommend performing a manual update in the terminal (a great way to familiarize yourself with the terminal and Debian’s package manager called apt).
For this drop into the terminal King’s Cross (also called kgx, it has a subway logo). On the terminal issue:
sudo apt update
sudo apt dist-upgrade
sudo apt autoremove
That's great, actually, I'll take a note, for the future!
Anyway, after downloading/flashing my SD again, as suggested, everything is working fine.
The OS immage was corrupted, indeed.
Problem solved Smile
Thanks again for your help!
Ciao
RE: Issues with Mobian 20210314 (data and updates) - by IMSAI8080 - 03-20-2021, 04:14 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,744 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,765 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,765 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 273,039 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,905 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
