Write to an A1-rated Micro SD card failed
It is weird, I agree.  As far as I know, A2-rated cards still work without enabling their additional features, albeit not at their maximum IOPS rate.  In my case, two A1-rated cards pretty much do not work as expected, which is weird.
I am running version 5.11.3 of the Linux kernel, which is the latest version in Manjaro ARM.  My intentions are to try running my A1-rated cards at a lower speed, with an additional delay prior to the card detection, etc.  If that doesn't help, I'll go through the differences between the Linux kernel drivers in the BSP and in the mainline.  I'll post the results, of course.
RE: Write to an A1-rated Micro SD card failed - by dsimic - 03-16-2021, 08:21 AM
  Both hinges completely failed phuzy 20 10,881 01-02-2024, 02:03 AM
Last Post: Uturn
  eMMC failed Dendrocalamus64 9 7,015 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,403 04-02-2021, 06:45 PM
Last Post: tkudog
  microSD card stuck charlesnorris 7 7,989 11-19-2020, 05:11 AM
  NVME SPI Update not booting SD Card WZ9V 5 6,414 10-18-2020, 08:36 PM
  Upgrade eMMC card - boot problems alpopa 0 2,281 09-16-2020, 12:31 PM
Last Post: alpopa
  PBP not booting screen blank after SD card boot Jakobp 10 13,707 08-18-2020, 08:56 PM
Last Post: trinapicot
  Privacy switches - cutting power to wifi card as400 1 2,788 08-10-2020, 09:48 AM
Last Post: belfastraven
  SD card slot stefan.schumacher 1 3,055 03-28-2020, 04:34 PM
Last Post: zaius
  USB-C HUB: sd card slots and USB ports not usable vfr400racer 2 4,121 12-15-2019, 03:50 AM
Last Post: vfr400racer
