Write to an A1-rated Micro SD card failed
mmh weird, afaik only A2 cards require any special handling to unlock features, I only have two A1 cards (Sandisk Extreme A1 16GB and Sandisk Ultra A1 16GB) but they both seem to work at SDR104 with either BSP (tested on older ayufan Debian image) and mainline (tested on Armbian).
My issues with sdcards were mostly related to various u-boot versions before the link training was up to the same level as in the linux drivers...
Can you test your cards at a lower bus speed, like DDR50 or just high speed?
Also what kernel version did your run?
RE: Write to an A1-rated Micro SD card failed - by xalius - 03-16-2021, 07:13 AM
  Both hinges completely failed phuzy 20 10,404 01-02-2024, 02:03 AM
Last Post: Uturn
  eMMC failed Dendrocalamus64 9 6,801 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,288 04-02-2021, 06:45 PM
Last Post: tkudog
  microSD card stuck charlesnorris 7 7,822 11-19-2020, 05:11 AM
  NVME SPI Update not booting SD Card WZ9V 5 6,249 10-18-2020, 08:36 PM
  Upgrade eMMC card - boot problems alpopa 0 2,239 09-16-2020, 12:31 PM
Last Post: alpopa
  PBP not booting screen blank after SD card boot Jakobp 10 13,464 08-18-2020, 08:56 PM
Last Post: trinapicot
  Privacy switches - cutting power to wifi card as400 1 2,728 08-10-2020, 09:48 AM
Last Post: belfastraven
  SD card slot stefan.schumacher 1 2,993 03-28-2020, 04:34 PM
Last Post: zaius
  USB-C HUB: sd card slots and USB ports not usable vfr400racer 2 4,028 12-15-2019, 03:50 AM
Last Post: vfr400racer
