Pine Phone Battery Issue
(03-04-2021, 01:02 PM)wibble Wrote: There have been reports elsewhere on the forum that the mobian kernel is stopping charging before 100%, possibly as a strategy to reduce battery capacity degradation in the long term. Other distros don't seem to be doing this. Did you see any difference in behaviour between distros?
Depending on whether the phone is suspending, and what power state the modem is going into, you could see long or short battery life. Assuming there's nothing faulty, a few hours suggests the modem is in a high power state, and the main cpu isn't suspending - and possibly that the display is kept on. The back of the phone being warm an inch or so below the camera would be indicative of the modem using a lot of power. If your phone is cool and the screen is off, but the battery life is still short, something odd is happening.
Random charge level reporting seems odd - I've not seen that, so it may indicate a fault. I'm not familiar enough with the battery management hardware to narrow it down though.
Thank you very much, this is a very nice guidance. I don't have the phone on hand right now (I'm not at home), and will try to see more deeply ASAP.
IIRC, I didn't see hi cpu usage on  'top', but since the modem is device related, I don't expect to see it there. I will investigate on interrupt request usage next time. Finally yes, the phone was hot (not too much, but like with a 100% cpu usage).  I didn't notice any difference in behavior btw distros, but I will put a more accurate eye next time.
Once again, many thanks for your tips, great. I will come back next week,
v/
Pine Phone Battery Issue - by vslash - 03-04-2021, 02:25 AM
RE: Pine Phone Battery Issue - by wibble - 03-04-2021, 01:02 PM
RE: Pine Phone Battery Issue - by vslash - 03-04-2021, 01:57 PM
RE: Pine Phone Battery Issue - by vslash - 03-19-2021, 09:52 AM
RE: Pine Phone Battery Issue - by mmance - 03-21-2021, 11:03 AM
RE: Pine Phone Battery Issue - by themontyhouse - 03-22-2021, 09:45 AM
RE: Pine Phone Battery Issue - by mteagles1942 - 03-22-2021, 12:36 PM
RE: Pine Phone Battery Issue - by Gribouille - 03-26-2021, 12:31 PM
RE: Pine Phone Battery Issue - by Zebulon Walton - 03-26-2021, 03:18 PM
RE: Pine Phone Battery Issue - by Gribouille - 03-27-2021, 01:12 AM
RE: Pine Phone Battery Issue - by Zebulon Walton - 03-30-2021, 12:04 PM
RE: Pine Phone Battery Issue - by Gribouille - 04-09-2021, 08:51 AM
RE: Pine Phone Battery Issue - by bcnaz - 08-09-2021, 05:53 AM
RE: Pine Phone Battery Issue - by Gribouille - 03-30-2021, 02:04 AM
RE: Pine Phone Battery Issue - by Veraendert - 03-30-2021, 07:21 AM
RE: Pine Phone Battery Issue - by Harry27 - 08-03-2021, 04:31 PM
RE: Pine Phone Battery Issue - by bcnaz - 08-03-2021, 08:44 PM
RE: Pine Phone Battery Issue - by mouffa - 08-04-2021, 04:01 AM
RE: Pine Phone Battery Issue - by bcnaz - 08-07-2021, 04:22 AM
RE: Pine Phone Battery Issue - by mouffa - 08-07-2021, 11:48 AM
RE: Pine Phone Battery Issue - by mouffa - 08-08-2021, 06:40 AM
RE: Pine Phone Battery Issue - by mouffa - 08-09-2021, 07:35 AM
  Battery connector dead mdk 5 3,164 01-15-2026, 02:24 PM
Last Post: mikeb
  My Phone stopped making and recieving Calls tracyanne 0 10,240 09-14-2025, 03:30 PM
Last Post: tracyanne
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 2,534 09-20-2024, 04:04 AM
  Phone powers off with high user demands car46999 7 7,577 04-11-2024, 09:17 AM
Last Post: zetabeta
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,294 02-17-2024, 04:15 PM
Last Post: vortex
  Phone will not turn on (but sometimes will) insidetrip101 10 12,275 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 3,123 07-31-2023, 07:50 PM
  Battery life improvement freelectro 10 10,020 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 4,529 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 3,184 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
