Product Idea: USB Flash Drives
#22
(03-16-2021, 05:11 PM)dsimic Wrote: That would be really neat! Cool  For a USB 2.0 storage device, using quad-SPI flash should provide more than enough speed, and would allow rather easy implementation of different RAID levels, while keeping the price of device low.
Yeah, I think it's quite feasible using the QSPI interface you suggest - it even mentions supporting up to four slaves. That should be more that enough to begin tests. For full speed QSPI we may run into problems with signals, etc, but we'll run into that when we get there.
(03-16-2021, 05:11 PM)dsimic Wrote: Is there enough documentation available for the BL602?
@lupyuen has done some epic work in this space: https://lupyuen.github.io/articles/book
I can't tell if he got QSPI working, but there is certainly more than enough to get going there.
(03-16-2021, 05:11 PM)dsimic Wrote: What about the USB interface, required for exposing the storage to the host?  I cannot see that available in the BL602?
Me neither, we might be looking at USB-SPI interface chip initially: https://ww1.microchip.com/downloads/en/D...22288A.pdf
We should in theory be using something with USB support already, but the BL602 is nice simply because the community already works on it and it has everything else we need, as well as being RISC-V. Developing hardware for the BL602 should be as simple as just developing a 'hat' PCB - which makes it quite attractive as a starting platform: https://files.pine64.org/doc/Pinenut/NUT...%201.0.pdf
(03-16-2021, 05:11 PM)dsimic Wrote: On second thought, I agree with you.  There's no way to know in advance what's actually inside an off-the-shelf USB flash drive, regardless of the actual make and model, which invalidates the whole idea about "harvesting" the parts.
Not to mention how difficult some of those chips may be to solder without damaging them in some way.
(03-16-2021, 05:11 PM)dsimic Wrote: Furthermore, no open storage device is easily and inexpensively available to pretty much anyone, which is the key, if you agree.  I wonder where and how could I buy one of the referenced OpenSSD development boards?  Even if buying those boards is actually possible, it would surely cost an arm and a leg, effectively rendering them unavailable.
I'm not sure you can buy them - and the added complexity overhead with all the crazy stuff it is able to do for the purpose of debugging.
Product Idea: USB Flash Drives - by barray - 03-03-2021, 05:57 AM
RE: Product Idea: USB Flash Drives - by Arwen - 03-04-2021, 02:25 PM
RE: Product Idea: USB Flash Drives - by Julius_GU - 03-05-2021, 01:33 PM
RE: Product Idea: USB Flash Drives - by Julius_GU - 03-05-2021, 03:59 PM
RE: Product Idea: USB Flash Drives - by barray - 03-05-2021, 07:04 PM
RE: Product Idea: USB Flash Drives - by barray - 03-05-2021, 09:23 PM
RE: Product Idea: USB Flash Drives - by Arwen - 03-07-2021, 03:33 PM
RE: Product Idea: USB Flash Drives - by barray - 03-07-2021, 04:59 PM
RE: Product Idea: USB Flash Drives - by barray - 03-07-2021, 11:15 PM
RE: Product Idea: USB Flash Drives - by Julius_GU - 03-14-2021, 12:05 PM
RE: Product Idea: USB Flash Drives - by Arwen - 03-14-2021, 01:40 PM
RE: Product Idea: USB Flash Drives - by barray - 03-14-2021, 02:01 PM
RE: Product Idea: USB Flash Drives - by Arwen - 03-14-2021, 02:18 PM
RE: Product Idea: USB Flash Drives - by barray - 03-14-2021, 03:12 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-15-2021, 04:00 PM
RE: Product Idea: USB Flash Drives - by barray - 03-15-2021, 04:31 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-15-2021, 08:32 PM
RE: Product Idea: USB Flash Drives - by barray - 03-16-2021, 02:43 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-16-2021, 03:21 PM
RE: Product Idea: USB Flash Drives - by barray - 03-16-2021, 04:42 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-16-2021, 05:11 PM
RE: Product Idea: USB Flash Drives - by barray - 03-16-2021, 06:02 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-16-2021, 06:36 PM
RE: Product Idea: USB Flash Drives - by barray - 03-16-2021, 08:23 PM
RE: Product Idea: USB Flash Drives - by Julius_GU - 03-17-2021, 02:04 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-19-2021, 05:47 AM
RE: Product Idea: USB Flash Drives - by barray - 03-17-2021, 07:02 PM
RE: Product Idea: USB Flash Drives - by barray - 03-17-2021, 10:26 PM
RE: Product Idea: USB Flash Drives - by barray - 03-20-2021, 12:26 AM
RE: Product Idea: USB Flash Drives - by dsimic - 03-20-2021, 03:08 AM
RE: Product Idea: USB Flash Drives - by barray - 03-20-2021, 04:37 AM
RE: Product Idea: USB Flash Drives - by dsimic - 03-20-2021, 05:47 AM
RE: Product Idea: USB Flash Drives - by barray - 03-21-2021, 12:01 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-21-2021, 03:48 PM
RE: Product Idea: USB Flash Drives - by barray - 03-21-2021, 04:18 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-21-2021, 04:56 PM
RE: Product Idea: USB Flash Drives - by barray - 03-21-2021, 10:39 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-22-2021, 12:11 AM
RE: Product Idea: USB Flash Drives - by barray - 03-22-2021, 12:19 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-26-2021, 06:59 AM
RE: Product Idea: USB Flash Drives - by LazLong - 03-22-2021, 06:20 PM
RE: Product Idea: USB Flash Drives - by barray - 03-23-2021, 04:37 AM
RE: Product Idea: USB Flash Drives - by LazLong - 03-23-2021, 02:02 PM
RE: Product Idea: USB Flash Drives - by israel - 03-23-2021, 06:02 AM
RE: Product Idea: USB Flash Drives - by barray - 03-23-2021, 04:33 PM
RE: Product Idea: USB Flash Drives - by barray - 03-27-2021, 02:06 AM
RE: Product Idea: USB Flash Drives - by dsimic - 03-27-2021, 03:00 AM
RE: Product Idea: USB Flash Drives - by barray - 03-28-2021, 01:47 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-28-2021, 03:04 PM
RE: Product Idea: USB Flash Drives - by barray - 03-28-2021, 03:28 PM
RE: Product Idea: USB Flash Drives - by dsimic - 03-28-2021, 09:46 PM
RE: Product Idea: USB Flash Drives - by barray - 03-29-2021, 08:09 AM
RE: Product Idea: USB Flash Drives - by dsimic - 04-01-2021, 07:50 AM
RE: Product Idea: USB Flash Drives - by xalius - 03-29-2021, 08:34 AM
RE: Product Idea: USB Flash Drives - by Arwen - 03-29-2021, 11:15 AM
RE: Product Idea: USB Flash Drives - by barray - 03-30-2021, 11:20 AM
RE: Product Idea: USB Flash Drives - by barray - 03-30-2021, 12:44 PM
RE: Product Idea: USB Flash Drives - by Arwen - 04-01-2021, 01:27 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-01-2021, 02:05 PM
RE: Product Idea: USB Flash Drives - by barray - 04-01-2021, 05:31 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-01-2021, 09:20 PM
RE: Product Idea: USB Flash Drives - by barray - 04-01-2021, 10:02 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-01-2021, 11:01 PM
RE: Product Idea: USB Flash Drives - by Arwen - 04-03-2021, 03:00 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-07-2021, 12:52 PM
RE: Product Idea: USB Flash Drives - by barray - 04-05-2021, 07:47 PM
RE: Product Idea: USB Flash Drives - by barray - 04-11-2021, 10:52 AM
RE: Product Idea: USB Flash Drives - by dsimic - 04-12-2021, 01:09 AM
RE: Product Idea: USB Flash Drives - by Arwen - 04-13-2021, 11:31 AM
RE: Product Idea: USB Flash Drives - by dsimic - 04-14-2021, 11:13 AM
RE: Product Idea: USB Flash Drives - by barray - 04-20-2021, 07:19 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-20-2021, 08:07 PM
RE: Product Idea: USB Flash Drives - by xalius - 04-21-2021, 08:45 AM
RE: Product Idea: USB Flash Drives - by barray - 04-21-2021, 08:32 PM
RE: Product Idea: USB Flash Drives - by xalius - 04-22-2021, 01:27 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-25-2021, 02:13 PM
RE: Product Idea: USB Flash Drives - by barray - 04-25-2021, 10:24 PM
RE: Product Idea: USB Flash Drives - by dsimic - 04-25-2021, 10:44 PM
RE: Product Idea: USB Flash Drives - by barray - 05-14-2021, 01:43 AM
RE: Product Idea: USB Flash Drives - by dsimic - 05-16-2021, 01:11 AM
RE: Product Idea: USB Flash Drives - by barray - 05-16-2021, 02:10 AM
RE: Product Idea: USB Flash Drives - by dsimic - 05-16-2021, 05:29 AM
RE: Product Idea: USB Flash Drives - by Arwen - 05-16-2021, 11:32 AM
RE: Product Idea: USB Flash Drives - by poVoq - 05-16-2021, 05:25 PM
RE: Product Idea: USB Flash Drives - by barray - 05-16-2021, 07:08 PM
RE: Product Idea: USB Flash Drives - by barray - 05-17-2021, 10:36 PM
RE: Product Idea: USB Flash Drives - by dsimic - 05-17-2021, 11:59 PM
RE: Product Idea: USB Flash Drives - by barray - 05-18-2021, 09:08 PM
RE: Product Idea: USB Flash Drives - by barray - 06-01-2021, 10:23 PM
RE: Product Idea: USB Flash Drives - by dsimic - 06-04-2021, 04:51 AM
RE: Product Idea: USB Flash Drives - by barray - 06-04-2021, 11:33 PM
RE: Product Idea: USB Flash Drives - by dsimic - 06-04-2021, 11:51 PM
RE: Product Idea: USB Flash Drives - by barray - 06-07-2021, 10:04 AM
RE: Product Idea: USB Flash Drives - by dsimic - 06-11-2021, 04:15 AM
RE: Product Idea: USB Flash Drives - by barray - 06-12-2021, 04:35 AM
RE: Product Idea: USB Flash Drives - by dsimic - 07-07-2021, 08:08 PM
RE: Product Idea: USB Flash Drives - by barray - 07-08-2021, 09:21 PM
RE: Product Idea: USB Flash Drives - by biketool - 07-09-2021, 03:09 AM
RE: Product Idea: USB Flash Drives - by dsimic - 07-09-2021, 03:27 AM
RE: Product Idea: USB Flash Drives - by biketool - 07-09-2021, 09:03 AM
RE: Product Idea: USB Flash Drives - by dsimic - 07-09-2021, 01:43 PM
RE: Product Idea: USB Flash Drives - by barray - 07-10-2021, 04:53 AM
RE: Product Idea: USB Flash Drives - by biketool - 07-10-2021, 11:54 AM
RE: Product Idea: USB Flash Drives - by barray - 07-12-2021, 01:08 AM
RE: Product Idea: USB Flash Drives - by tarksur - 09-01-2022, 01:19 PM
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,496 07-24-2023, 03:21 PM
Last Post: Omnios
  QuartzPro64 SPI flash Melab 1 894 03-16-2023, 07:50 PM
Last Post: Melab
  Modular product design Zotax 0 849 01-28-2023, 11:50 AM
Last Post: Zotax
  Product Idea: PineTracker EternityForest 0 782 01-12-2023, 10:33 PM
Last Post: EternityForest
  New product idea: Pine Glasses Blathers 2 2,766 12-02-2022, 09:51 PM
Last Post: erikzoltan
Lightbulb Product Idea: Pine Graphics Tablet israel 10 8,258 04-19-2022, 04:12 AM
Last Post: Houstand345
  Article: Auto Flash and Test NuttX on RISC-V BL602 (PineCone) lupyuen 0 1,278 01-24-2022, 05:41 PM
Last Post: lupyuen
  Rackmount cluster case as a Pine Store product? dfr 3 3,361 09-30-2021, 04:52 PM
Last Post: poVoq
  E-Note Device (E-Ink, E-Paper, Project Idea) Sirius 9 9,101 08-18-2021, 08:28 AM
  PineVR as a new product? poVoq 11 11,439 05-31-2021, 09:33 AM
Last Post: MirceaKitsune
