C GPIO
Martin, I want to thank you too. You have answered many questions I have had about the /dev/mem and about the manual; really, thanks !
It may turn out that there is something over-riding your /dev/mem writes with C (I don't know, I'm just suspicious because I have seen this type of behavior on the Pine board in other areas. (other dts|dtb definitions, and other drivers)
It may also be, and unfortunately probably is, that the manual is out-of-date. We know in fact that the schematic is out-of-date... and we are still waiting to see the schematic that matches the 2G PineA64+ , and we are still waiting for the updated manual. So, we might just have to keep waiting, or keep experimenting. If you know that your GPIO68 works (by using sysfs) then we know this is not a hardware problem! ... and, that the manual you are attempting to follow is probably not correct for this board.
edit: PS... the GPIO12 number is the Raspberry PI Broadcom GPIO pin numbering scheme. It means absolutely 'nothing' for your C code. It is only important for codes library like RPi.GPIO-PineA64 , which is a Raspberry PI GPIO emulator... and can be coded with either BOARD numbering or BCM numbering.
Sysfs must use Pine GPIO numbering. I suspect your C code must use the offsets that match the Pine GPIO numbering scheme.
C GPIO - by igna09 - 06-10-2016, 12:41 PM
RE: C GPIO - by martinayotte - 06-10-2016, 01:52 PM
RE: C GPIO - by igna09 - 06-10-2016, 02:16 PM
RE: C GPIO - by martinayotte - 06-10-2016, 03:10 PM
RE: C GPIO - by martind1983 - 08-24-2016, 09:55 AM
RE: C GPIO - by igna09 - 06-11-2016, 02:51 AM
RE: C GPIO - by martinayotte - 08-25-2016, 07:35 AM
RE: C GPIO - by martind1983 - 08-25-2016, 08:24 AM
RE: C GPIO - by MarkHaysHarris777 - 08-25-2016, 11:17 AM
RE: C GPIO - by martind1983 - 08-29-2016, 01:30 AM
RE: C GPIO - by martind1983 - 08-29-2016, 03:50 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:25 AM
RE: C GPIO - by martind1983 - 08-31-2016, 03:47 AM
RE: C GPIO - by pfeerick - 08-31-2016, 04:14 AM
RE: C GPIO - by martind1983 - 08-31-2016, 04:36 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:04 PM
RE: C GPIO - by MarkHaysHarris777 - 08-31-2016, 04:09 AM
RE: C GPIO - by KnReLe - 08-31-2016, 07:27 AM
RE: C GPIO - by martind1983 - 09-01-2016, 05:08 AM
RE: C GPIO - by MarkHaysHarris777 - 09-01-2016, 05:29 AM
RE: C GPIO - by martind1983 - 09-01-2016, 08:04 AM
RE: C GPIO - by KnReLe - 09-01-2016, 08:52 AM
RE: C GPIO - by martind1983 - 09-01-2016, 09:06 AM
  RPi.GPIO python module for Pine A64/A64+ aquilegia 98 131,429 12-15-2022, 08:40 PM
Last Post: Fadazo
  fm transmitter with gpio weasel18 2 4,827 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,593 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,115 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,195 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,844 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,566 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,755 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,156 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 6,089 11-10-2016, 06:07 PM
Last Post: joseph
