UFW (uncomplicated firewall) Start On Boot - Mobian (working)
Hey Ya'll,
Not entirely sure if others are wanting this, but thought I'd share my fix on this workaround if you been trying to get this firewall to start on system startup on mobian (fix will be similar to almost any Distro actually).
This is for anyone that wanted to use the UFW - uncomplicated firewall service vs iptables.
Useful background knowledge:
https://www.freedesktop.org/wiki/Softwar...orkTarget/
Assuming you have already installed ufw:
edit the /lib/systemd/system/ufw.service
sudo nano /lib/systemd/system/ufw.service
Comment or delete out any existing BEFORE and/or AFTER lines under [unit] and add the new conditions - should look similar to this:
[Unit]
Description=Uncomplicated firewall
Documentation=man:ufw(8)
DefaultDependencies=no
#Before=network.target
Before=network-pre.target
Wants=network-pre.target
Make sure you write out, save, and exit. What this does is makes sure the firewall starts BEFORE any network configuration. Which is the point of a firewall Smile
Add ufw.service to system startup
sudo systemctl enable ufw.service
Now also make sure ufw.conf has start on boot enabled (enabling just this without the above had no affect on startup). Edit the ufw.conf
sudo nano /etc/ufw/ufw.conf
ENABLED=yes
Write out and save and exit.
Reboot your phone. Once it is rebooted, head to terminal and check the firewall status:
sudo ufw status
Should be active on startup without having to manually enable it. This fix worked for me, hopefully it works for others - for anyone that also wants to use the ufw
UFW (uncomplicated firewall) Start On Boot - Mobian (working) - by theD0ctor - 02-28-2021, 01:15 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,744 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,765 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,766 09-15-2025, 02:42 AM
Last Post: georgegohl888
  New Install, apps start but don't show up on screen?! RT3 2 1,798 07-18-2025, 07:56 PM
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 273,039 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,906 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
