Cannot update
(02-28-2021, 07:42 PM)matt_the_hall Wrote: Thanks folks for the assistance and link to the blog!
Now, I had already steamed ahead with an apt update, apt upgrade (with the packages that weren't installed) before reading the blog. The blog suggests 'sudo apt dist-upgrade,' however, in the Software app, the message is that everything is "all up to date." Is it still worth doing the 'dist-upgrade?'
So far, the upgrade I did do has improved performance, significantly. However, web browsing is still a bit excruciating (because it is slow). As I got this phone knowing it was a prototype, and because I am trying  to do less phone use in general, I am ok with the slow browsing. However, as I am also hoping to contribute to this great project, I am wondering __why__ browsing is slow. It seems like 3 gigs of ram should be enough to handle simple website browsing. Any explanation on that, as well as how I can contribute to the project, that would be awesome.
Last question -- even after using Linux as my main operating system for a couple of years, I still don't get the difference between apt versus apt-get. It seems like apt-get is outmoded by apt, but, anyway, I see both used interchangeably all over the web -- perhaps someone can set me straight.
Loving the phone and Mobian so far, and looking forward to endless tinkering.
Best,
Matt
Yes to sudo apt dist-upgrade because it will repair the repository discrepancies in your installed apps.
Follow ALL the instructions here to install Chromium. I think you will find it faster then Firefox.
https://forum.pine64.org/showthread.php?tid=13235
Also rate me a +1 in the ratings if I helped you please? It makes up for the lack of pay they pay me here. Big Grin
Cannot update - by matt_the_hall - 02-27-2021, 08:09 PM
RE: Cannot update - by RodneyMyers - 02-28-2021, 05:14 AM
RE: Cannot update - by matt_the_hall - 02-28-2021, 11:33 AM
RE: Cannot update - by RodneyMyers - 02-28-2021, 12:02 PM
RE: Cannot update - by C0ffeeFreak - 02-28-2021, 02:33 PM
RE: Cannot update - by matt_the_hall - 02-28-2021, 07:42 PM
RE: Cannot update - by C0ffeeFreak - 02-28-2021, 08:00 PM
RE: Cannot update - by Harry27 - 03-03-2021, 02:56 PM
RE: Cannot update - by C0ffeeFreak - 03-03-2021, 04:22 PM
  Mobian PIN changed after update! Mwo87 21 17,742 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  No longer waking up from sleep after recent update gamerminstrel 2 1,307 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  no sdcard boot and manjaro update failed Gwen 3 1,406 11-27-2022, 07:56 AM
Last Post: fxc
Exclamation No wIfI after Mobian update crakabeats 3 2,113 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  update kills keyboard ludgate 1 1,179 05-18-2022, 12:43 AM
Last Post: programmin
  Unable to get PinePhone Manjaro - Arm to Update kmk7x 1 3,514 03-02-2021, 05:56 PM
Lightbulb [12.11.20 Update] Latest PinePhone CE Manjaro - Device Arrival & Initial Tests Thread kern707 11 12,294 12-25-2020, 10:23 PM
Last Post: crevdunekin
  Manjaro system update failed, bricked PinePhone jalanga 1 2,821 11-27-2020, 12:30 AM
Last Post: Veraendert
  How To Update Phone? K_Research 3 3,995 07-24-2020, 09:10 AM
Last Post: wibble
  Update on last batch of Bravehearts not yet shipped nimji 16 17,947 03-13-2020, 09:57 AM
Last Post: someGermanGuy
