Installing and tweaking Chromium on Mobian and Arch
(02-26-2021, 07:54 PM)Zebulon Walton Wrote:
(02-26-2021, 12:22 PM)C0ffeeFreak Wrote: From the home screen select the extensions in the top bar (looks like a puzzle piece) and select the extension not the three dots on the side of it and you will see the selection drop down. You may have to make your selections in landscape mode until you get the mobile user agent string set.
Thanks, that did the trick, but it looks like the latest version of Chrome available in the extension is 87.0.4280.101, not 4290. I found that scale-to-fit Chromium on didn't really seem to do anything, but I used the screen scaling script that was posted on the board here (I think it was from here) to make the browser a better fit on the screen. I could not find a link to the that script but it's here below, I've found the 1.75x scale setting works well for Chromium without making things on the screen too small to see. I run it from a .desktop file placed in ~/.local/share/applications.
#!/bin/bash
yad --title scale_screen --form \
  --field='Default dpi (2x scale)':fbtn "wlr-randr --output DSI-1 --scale 2" \
  --field='Low dpi (1.75x scale)!window-restore-symbolic':fbtn "wlr-randr --output DSI-1 --scale 1.75" \
  --field='Medium dpi (1.5x scale)!window-minimize-symbolic':fbtn "wlr-randr --output DSI-1 --scale 1.5" \
  --field='High dpi (1.25x scale)!window-maximize-symbolic':fbtn "wlr-randr --output DSI-1 --scale 1.25" \
  --field='Max dpi (1x scale)!view-fullscreen-symbolic':fbtn "wlr-randr --output DSI-1 --scale 1" \
  --field='Restart Phosh':fbtn "sudo systemctl restart phosh" \
  --button='Close!gtk-cancel':1
Is the name of the file Chromium.desktop? I tried it and no results.
RE: Installing and tweaking Chromium on Mobian and Arch - by C0ffeeFreak - 03-03-2021, 11:54 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,745 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,765 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,766 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 273,039 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,906 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
