Installing and tweaking Chromium on Mobian and Arch
(02-25-2021, 07:54 PM)C0ffeeFreak Wrote: After Chromium opens type chrome://flags in the address bar and hit enter. After it opens search for Freeze User-Agent request header and enable it then close the browser.
Open Chromium go to settings-more tools-extensions search for and install Use-Agent Switcher and Manager.
Open the extension and choose Chrome and Android in the drop down. Then select Chrome 87.0.4290.101  Android 10  and at the bottom left select Apply (all windows)
I'm trying this, and already had installed org.chromium.Chromium through flatpak. I've set the flags option and installed User-Agent Switcher and Manager. I think I got the right extension:
https://chrome.google.com/webstore/detai...bfkg?hl=en
However,  I'm not seeing a drop-down list of user agents to select from, only extension settings such as blacklist and whitelist mode. Is there a trick to getting to the dropdown, maybe it's hard to see on the Pinephone screen?
RE: Installing and tweaking Chromium on Mobian and Arch - by Zebulon Walton - 02-26-2021, 11:10 AM
  Axolotl on PinePhone / Mobian arno_nuehm 113 32,098 2 hours ago
Last Post: dante404
  Why do you use mobian? unrealb2 16 448 6 hours ago
Last Post: MNtinkerer
  Mobian September 13 Nightly bcnaz 1 121 09-14-2021, 03:50 PM
Last Post: bcnaz
  Updating old Mobian installation? SocialNetworkingWasAMistake 1 52 09-14-2021, 03:41 PM
Last Post: bcnaz
  Installing Mobian --> "Resizing file system" forever Anna 13 2,815 09-09-2021, 04:26 AM
Last Post: spaetz
  I'd like to have a Discord client on Mobian lsitongia 2 137 09-03-2021, 06:56 PM
Last Post: ryo
  Mobian September 01, 2021 bcnaz 2 290 09-01-2021, 11:45 AM
Last Post: bcnaz
  Mobian 'HotSpot" bcnaz 2 349 08-29-2021, 07:34 AM
Last Post: bcnaz
  mobile data on mobian not working synaption 10 773 08-29-2021, 07:22 AM
Last Post: bcnaz
  Hot Spot on Mobian/Bookworm ? bcnaz 1 149 08-29-2021, 02:47 AM
Last Post: bcnaz
