SD card mounted to access music files unable to play
I just had the Manjaro Plasma Mobile testing 20210224 update (make sure you set brightness to max, I had mine low and couldn't see thing when it rebooted, finally figured out increasing brightness via ssh did the trick).
With the latest vvave, I could add the ogg folder explicitly as a music source and it sees all the content and plays it fine,, too.
I haven't changed anything since this post, so it seems all is now good!
RE: SD card mounted to access music files unable to play - by dcinoz - 02-24-2021, 11:48 PM
  Access to system directories from flatpak lagrang3 2 4,259 02-25-2025, 05:02 PM
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 1,906 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 2,868 08-22-2023, 12:22 PM
  Introducing Harborz: Lightweight Rust Music Player for Pinephone ravenblackdusk 1 2,500 08-07-2023, 12:05 AM
Last Post: ravenblackdusk
  Device memory full on multi-boot SD card Peter Gamma 4 5,147 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 5,897 08-17-2022, 03:38 AM
Last Post: shulamy
  Help wanted: location of calls and chatty data files dukla2000 3 6,949 06-13-2022, 02:01 PM
Last Post: israel
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 5,272 05-02-2022, 06:57 AM
  Writing to SD card possible with all applications? Peter Gamma 5 6,174 03-28-2022, 07:12 AM
  music making? wakyct 5 6,375 12-08-2021, 03:21 AM
Last Post: ryo
