Plasma Mobile airplane / aeroplane mode / mobile off
Evening here and I normally put my phone in airplane / aeroplane mode i.e. would look for a toggle to disable modem / mobile data / wifi / BT if any are on.
I could find no such thing on Manjaro Plasma Mobile 20210221.
I panicked when I went to settings and saw internet had a tick - even though the Mobile Data icon in the top bar settings is not on....does that toggle not work?
So surprise, no mobile modem off either. Or could the Mobile Data icon actually toggle mobile / mobile data on / off?
I have my mobile modem on with data off due to cost.
I did not find a quick way to turn data on / off via ofono command.
Neither a way to turn mobile modem on / off via ofono.
I did a brutal
sudo pkill ofonod
and that worked - no more mobile icon in the top bar.
I lodged a bug report at https://gitlab.manjaro.org/manjaro-arm/i.../issues/69
I appreciate any comments from anyone with more Plasma Mobile experience. Mobian has quirks including with their Airplane toggle (still not fixed....) but you can turn mobile on / off, data on / off.
I assume this bug report covers the mobile data icon toggle:
https://gitlab.manjaro.org/manjaro-arm/i...-/issues/9
Plasma Mobile airplane / aeroplane mode / mobile off - by dcinoz - 02-22-2021, 05:54 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,335 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,366 03-02-2023, 07:25 PM
  Flight mode turns off wifi but not the modem (cellular) jojuma 2 1,286 02-28-2023, 01:58 PM
Last Post: calinb
  gnome-mobile dev Uturn 1 1,040 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 4,572 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,481 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,029 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,220 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 28,590 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 944 07-04-2022, 11:42 AM
Last Post: tuxmain
