Battery Dead on Arrival?
Is this the sealed or unsealed version? If sealed, your debugging abilities will be limited...
Some initial ideas:
1. When attached to the base, what is the version number you get in the software?
2. (Unsealed) Check the battery is soldered correctly in the device. It sounds like the battery is offering next to zero supply to the device off power.
3. (Unsealed) Check there is a voltage across the battery terminals whilst connected (under load) - ideally 3V+. If it's below, then there's a good chance the battery has had some damage.
Battery Dead on Arrival? - by mpz - 02-14-2021, 11:59 AM
RE: Battery Dead on Arrival? - by barray - 02-14-2021, 01:21 PM
RE: Battery Dead on Arrival? - by mpz - 02-14-2021, 09:31 PM
RE: Battery Dead on Arrival? - by barray - 02-16-2021, 03:49 AM
RE: Battery Dead on Arrival? - by Avamander - 02-16-2021, 06:01 AM
RE: Battery Dead on Arrival? - by jferg - 02-16-2021, 08:16 PM
RE: Battery Dead on Arrival? - by barray - 02-17-2021, 04:05 AM
RE: Battery Dead on Arrival? - by danielt - 02-17-2021, 04:08 AM
RE: Battery Dead on Arrival? - by Avamander - 02-21-2021, 01:18 PM
RE: Battery Dead on Arrival? - by Mpoint - 03-30-2021, 04:43 PM
  PineTime is dead!! Markdanni123 12 14,039 09-18-2023, 10:17 PM
Last Post: ccchan234
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 1,198 03-13-2023, 05:05 PM
Last Post: PiningFjord
  PineTime Dead out of box? henkery 1 1,266 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,938 02-11-2023, 09:30 AM
Last Post: alexmitroff
Question Open box, upgrade, dead watch? ahaplesshappenstance 5 2,914 06-25-2022, 03:13 PM
Last Post: ahaplesshappenstance
Question Battery indicator calibration sal 0 1,029 02-06-2022, 08:51 AM
Last Post: sal
  BT toggle/battery life ronaldheld 0 972 02-04-2022, 04:46 AM
Last Post: ronaldheld
  Battery Life Indicator Percentage Frowzzen 3 2,359 12-28-2021, 02:16 PM
Last Post: ITCactus
