PBP won't power. Charge light solid orange/red but turns off.
SUMMARY OF THREAD
Symptoms: Laptop (with power bypass connected and battery disconnected) powers immediately on power being plugged in and then turns off after about 3 seconds (i.e. shortly after the display starts). The laptop should not do this. After plugging in the power, the laptop should only power on after pressing the power button. Other symptoms included (1) various kernel messages about voltage problems in connection with CPU and other peripherals (provided over UART) and (2) brief high pitch low volume noise from display or main board (possibly because of insufficient voltages).
Problem: Faulty keyboard.
Solution: Swap keyboard.
Other comments: The Pine Team had sent through a replacement display and keyboard (because of an earlier unrelated postal issue, not their fault and it was very kind of them to send the replacement parts through). I had received it about a week or two ago but only had a chance to look at them today. Swapped over the keyboard this morning and FreeBSD from the eMMC boots without problem!
I'll leave this thread open until I finish swapping over all the parts.
Thanks again for everyone's help!
UPDATE: Finished swapping over all parts. Took a while because I was testing as I swapped parts over. All working now!
RE: PBP won't power. Charge light solid orange/red but turns off. - by cmicallef - 03-12-2021, 07:08 PM
  New RockPro64 Power Up Problem enorbet2 7 4,989 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,855 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,929 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,412 03-14-2021, 09:05 AM
Last Post: xalius
  Cannot charge and NO Wifi? jiapei100 3 5,467 06-27-2020, 02:11 PM
Last Post: jiapei100
  howto power hdd via usb3 on rockpro64 hanscees 2 5,079 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,748 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,076 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,542 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,099 10-23-2016, 12:16 PM
Last Post: dkryder
