PBP won't power. Charge light solid orange/red but turns off.
Okay, this really sounds to me like U-boot runs, and hands over control to the operating system, which crashes early.
Lets leave the eMMC turned off for now.
1) What operating system image are you trying to boot from Micro SD?
2) Have you tried a different Micro SD card?
3) How are you writing the image to the SD card?
4) Do you have a UART cable (beware there are "right" looking cables which can cause damage)?
I highly recommend the original PBP operating system image, "Debian Desktop" which can be found in the wiki, for these situations It seems to be the most likely to work in these situations. There have been many reports of SD cards that do not work properly, even a few reports of SD cards that once worked, which now do not. I only ever write SD cards with `dd`. I am not familiar with other methods, but many people report having other preferences.
It may sound ridiculous, but it is pretty common to have a buggered eMMC and an SD card that won't boot, at the same time. Usually after trying relentlessly, the PBP will just suddenly work with a particular SD card; and then you can rewrite the eMMC and get back to normal business. I hope this is your case.
If you should have a UART cable, and a way to use the serial console, this may give you more insight to what's actually happening.
RE: PBP won't power. Charge light solid orange/red but turns off. - by KC9UDX - 02-14-2021, 05:04 PM
  New RockPro64 Power Up Problem enorbet2 7 4,986 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,855 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,929 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,412 03-14-2021, 09:05 AM
Last Post: xalius
  Cannot charge and NO Wifi? jiapei100 3 5,465 06-27-2020, 02:11 PM
Last Post: jiapei100
  howto power hdd via usb3 on rockpro64 hanscees 2 5,078 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,746 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,074 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,540 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,098 10-23-2016, 12:16 PM
Last Post: dkryder
