Unusable ROCKPRO64
(02-13-2021, 07:06 PM)tllim Wrote:
(02-09-2021, 10:09 AM)drenedo Wrote: Hi all,
            after running well for 25 days more or less, my rockpro64 is unusable. All USB ports and ethernet port are not working. I tried with many images, Manjaro, armbian... to top it all sometimes the startup finish with a kernel panic message.
I'm pretty sure that this is a hardware failure. Has anyone a similar experience? I'm very disgusted, the rockpro64 only ran for 25 days more or less. I have had others SBC, like raspberry pi, in the same place for years without problems.
Sad
Please make sure that your power supply rated 12V 3A or 5A. Looks like your board not getting enough power. If you are using teh Raspberry Pi power power which is 5V, then for sure is under power.
The power supply is correct. 12V 5A.
Unusable ROCKPRO64 - by drenedo - 02-09-2021, 10:09 AM
RE: Unusable ROCKPRO64 - by tllim - 02-13-2021, 07:06 PM
RE: Unusable ROCKPRO64 - by drenedo - 02-15-2021, 01:49 AM
RE: Unusable ROCKPRO64 - by GuyNoIRQ - 03-24-2021, 06:47 AM
  NAS Optimizations for RockPro64 MNtinkerer 8 869 6 hours ago
Last Post: MNtinkerer
  How to run Raspberry Pi software on RockPro64? pk245 0 134 06-24-2022, 08:20 AM
Last Post: pk245
  OPNsense for RockPro64 one8three 1 171 06-18-2022, 08:48 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 101 06-09-2022, 10:56 AM
Last Post: pspgarret
  RockPro64 has no white led, nor will it boot past... AnjinMeili 2 163 05-31-2022, 09:19 AM
Last Post: Rocklobster
  RockPro64 Debian xrdb -- problem connecting emarsh 0 141 05-19-2022, 09:55 AM
Last Post: emarsh
  Booting my RockPro64 from NVMe drive PsySc0rpi0n 4 2,835 05-11-2022, 02:35 PM
Last Post: PsySc0rpi0n
  rockpro64 emmc GreyLinux 8 2,686 11-08-2021, 01:56 PM
Last Post: GreyLinux
  ROCKPro64 sometimes doesn't Power On Pete Tandy 2 1,735 08-24-2021, 05:50 AM
Last Post: Pete Tandy
  Tutorial request: overclocking a rockpro64 Mentaluproar 1 1,334 08-15-2021, 01:35 PM
Last Post: dukla2000
