Fail safe way to update ANX7688 firmware
(02-09-2021, 04:11 PM)scholbert Wrote: Hi,
i guess you'll need to have root privileges and make sure your kernel is below version 5.10.
Just added the sudo command to the first post.
BTW, the PMOS factory test image uses kernel 5.7 and everything was nice.
Good luck!
Cheers,
scholbert
Many thanks for your quick reply!
I am superuser on the system but I still get the error-message Sad
But I checked my kernel-version and its 5.10 Sad
So I've to wait until the timeout-problem is solved anyways.
Thanks and best regards from Vienna,
Andrew >:o)
RE: Fail safe way to update ANX7688 firmware - by AndrewBlackmiller - 02-10-2021, 09:58 AM
  firmware udate Quectel EG25-G modem alwi 7 11,118 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 5,988 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 33,934 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 2,587 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 29,277 05-11-2021, 02:45 AM
Last Post: frimmel
  Pinephone mainboard v1.2 documentation update? scholbert 1 3,861 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 20,757 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 5,328 11-09-2020, 04:40 PM
Last Post: tlo
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 5,315 10-04-2020, 11:18 PM
Last Post: Vlodka
